I am trying to use let’s encrypt for my domain https://socialserviceshop.com
www.socialserviceshop.com and socialserviceshop.com are not secure but when you add https:// it’s secured
Please help!
Thanks
Please help!
Thanks
Browsers “default” to non-HTTPS (i.e., HTTP ), unless you add a HPKP header ór configure a redirect in your webserver.
As you do not point out which command you ran (and consequently which client you used is unknown; why did you remove the initial questions provided to you when opening this thread anyway?), I can’t give you a clear answer on how to proceed: certbot
would have given you the option, but YMMV when using other clients.
