It produced this output: "Your connection is not private
Attackers might be trying to steal your information from www.goeasyshuttle.com (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID" Plus when I checked 'SSL Server Test', I got this outcomes "Common names: goeasyshuttle.com Alternative names: goeasyshuttle.com
The operating system my web server runs on is (include version): ubuntu 22
My hosting provider, if applicable, is: AWS ec2
No. If you explain how you got your first cert we can give more specific advice. Are you using Certbot for this cert the same as your certs from earlier threads?
That is a good step but I don't think you did it right. Requests to goeasyshuttle.com and the www domain do not return the same results. One gives a 301 redirect and the other a 404 page not found to requests for your home page.
You can do it like Rudy suggests with just the one return 301 and remove the other return 404 too. But, Certbot may have already changed it since you got the second name in the cert now. Had you given Certbot both names to start with it would have made your port 80 server block like this:
