I removed the sslvhost file then edited the ssl.conf file and the httpd server restartedâŚ
When we also provide SSL we have to listen to the
the HTTPS port in addition.
Listen 443 https
SSL Global Context
All SSL configuration in this context applies both to
the main server and all SSL-enabled virtual hosts.
Pass Phrase Dialog:
Configure the pass phrase gathering process.
The filtering dialog program (`builtinâ is a internal
terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog exec:/usr/libexec/httpd-ssl-pass-dialog
Inter-Process Session Cache:
Configure the SSL Session Cache: First the mechanism
to use and second the expiring timeout (in seconds).
SSLSessionCache shmcb:/run/httpd/sslcache(512000)
SSLSessionCacheTimeout 300
Pseudo Random Number Generator (PRNG):
Configure one or more sources to seed the PRNG of the
SSL library. The seed data should be of good random quality.
WARNING! On some platforms /dev/random blocks if not enough entropy
is available. This means you then cannot use the /dev/random device
because it would lead to very long connection times (as long as
it requires to make more entropy available). But usually those
platforms additionally provide a /dev/urandom device which doesnât
block. So, if available, use this one instead. Read the mod_ssl User
Manual for more details.
SSLRandomSeed startup file:/dev/urandom 256
SSLRandomSeed connect builtin
#SSLRandomSeed startup file:/dev/random 512
#SSLRandomSeed connect file:/dev/random 512
#SSLRandomSeed connect file:/dev/urandom 512
Use âSSLCryptoDeviceâ to enable any supported hardware
accelerators. Use âopenssl engine -vâ to list supported
engine names. NOTE: If you enable an accelerator and the
server does not start, consult the error logs and ensure
your accelerator is functioning properly.
SSLCryptoDevice builtin
#SSLCryptoDevice ubsec
SSL Virtual Host Context
General setup for the virtual host, inherited from global configuration
DocumentRoot â/var/www/htmlâ
ServerName grmc-web.grahamrmc.com
Use separate log files for the SSL virtual host; note that LogLevel
is not inherited from httpd.conf.
ErrorLog logs/ssl_error_log
TransferLog logs/ssl_access_log
LogLevel warn
SSL Engine Switch:
Enable/Disable SSL for this virtual host.
SSLEngine on
SSL Protocol support:
List the enable protocol levels with which clients will be able to
connect. Disable SSLv2 access by default:
SSLProtocol all -SSLv2 -SSLv3
SSL Cipher Suite:
List the ciphers that the client is permitted to negotiate.
See the mod_ssl documentation for a complete list.
SSLCipherSuite HIGH:3DES:!aNULL:!MD5:!SEED:!IDEA >>>>orginial config here, adding new on next line
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
Disable preloading HSTS in case of issues with CloadFlare
Header always set Strict-Transport-Security âmax-age=63072000; includeSubdomainsâ
Header always set X-Frame-Options DENY
Header always set X-Content-Type-Options nosniff
Speed-optimized SSL Cipher configuration:
If speed is your main concern (on busy HTTPS servers e.g.),
you might want to force clients to specific, performance
optimized ciphers. In this case, prepend those ciphers
to the SSLCipherSuite list, and enable SSLHonorCipherOrder.
Caveat: by giving precedence to RC4-SHA and AES128-SHA
(as in the example below), most connections will no longer
have perfect forward secrecy - if the serverâs key is
compromised, captures of past or future traffic must be
considered compromised, too.
#SSLCipherSuite RC4-SHA:AES128-SHA:HIGH:MEDIUM:!aNULL:!MD5
SSLHonorCipherOrder on
Server Certificate:
Point SSLCertificateFile at a PEM encoded certificate. If
the certificate is encrypted, then you will be prompted for a
pass phrase. Note that a kill -HUP will prompt again. A new
certificate can be generated using the genkey(1) command.
#SSLCertificateFile /etc/pki/tls/certs/localhost.crt
SSLCertificateFile /etc/letsencrypt/live/grmc-web.grahamrmc.com/cert.pem
Server Private Key:
If the key is not combined with the certificate, use this
directive to point at the key file. Keep in mind that if
youâve both a RSA and a DSA private key you can configure
both in parallel (to also allow the use of DSA ciphers, etc.)
#SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
SSLCertificateKeyFile /etc/letsencrypt/live/grmc-web.grahamrmc.com/privkey.pem
Server Certificate Chain:
Point SSLCertificateChainFile at a file containing the
concatenation of PEM encoded CA certificates which form the
certificate chain for the server certificate. Alternatively
the referenced file can be the same as SSLCertificateFile
when the CA certificates are directly appended to the server
certificate for convinience.
#SSLCertificateChainFile /etc/pki/tls/certs/server-chain.crt
SSLCertificateChainFile /etc/letsencrypt/live/grmc-web.grahamrmc.com/chain.pem
Certificate Authority (CA):
Set the CA certificate verification path where to find CA
certificates for client authentication or alternatively one
huge file containing all of them (file must be PEM encoded)
#SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
Client Authentication (Type):
Client certificate verification type and depth. Types are
none, optional, require and optional_no_ca. Depth is a
number which specifies how deeply to verify the certificate
issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
Access Control:
With SSLRequire you can do per-directory access control based
on arbitrary complex boolean expressions containing server
variable checks and other lookup directives. The syntax is a
mixture between C and Perl. See the mod_ssl documentation
for more details.
#SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
and %{SSL_CLIENT_S_DN_O} eq âSnake Oil, Ltd.â \
and %{SSL_CLIENT_S_DN_OU} in {âStaffâ, âCAâ, âDevâ} \
and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \
or %{REMOTE_ADDR} =~ m/^192.76.162.[0-9]+$/
SSL Engine Options:
Set various options for the SSL engine.
o FakeBasicAuth:
Translate the client X.509 into a Basic Authorisation. This means that
the standard Auth/DBMAuth methods can be used for access control. The
user name is the `one lineâ version of the clientâs X.509 certificate.
Note that no password is obtained from the user. Every entry in the user
file needs this password: `xxj31ZMTZzkVAâ.
o ExportCertData:
This exports two additional environment variables: SSL_CLIENT_CERT and
SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
server (always existing) and the client (only existing when client
authentication is used). This can be used to import the certificates
into CGI scripts.
o StdEnvVars:
This exports the standard SSL/TLS related `SSL_*â environment variables.
Per default this exportation is switched off for performance reasons,
because the extraction step is an expensive operation and is usually
useless for serving static content. So one usually enables the
exportation for CGI and SSI requests only.
o StrictRequire:
This denies access when âSSLRequireSSLâ or âSSLRequireâ applied even
under a âSatisfy anyâ situation, i.e. when it applies access is denied
and no other module can change it.
o OptRenegotiate:
This enables optimized SSL connection renegotiation handling when SSL
directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<Files ~ â.(cgi|shtml|phtml|php3?)$â>
SSLOptions +StdEnvVars
<Directory â/var/www/cgi-binâ>
SSLOptions +StrictRequire
SSL Protocol Adjustments:
The safe and default but still SSL/TLS standard compliant shutdown
approach is that mod_ssl sends the close notify alert but doesnât wait for
the close notify alert from client. When you need a different shutdown
approach you can use one of the following variables:
o ssl-unclean-shutdown:
This forces an unclean shutdown when the connection is closed, i.e. no
SSL close notify alert is send or allowed to received. This violates
the SSL/TLS standard but is needed for some brain-dead browsers. Use
this when you receive I/O errors because of the standard approach where
mod_ssl sends the close notify alert.
o ssl-accurate-shutdown:
This forces an accurate shutdown when the connection is closed, i.e. a
SSL close notify alert is send and mod_ssl waits for the close notify
alert of the client. This is 100% SSL/TLS standard compliant, but in
practice often causes hanging connections with brain-dead browsers. Use
this only for browsers where you know that their SSL implementation
works correctly.
Notice: Most problems of broken clients are also related to the HTTP
keep-alive facility, so you usually additionally want to disable
keep-alive for those clients, too. Use variable ânokeepaliveâ for this.
Similarly, one has to force some clients to use HTTP/1.0 to workaround
their broken HTTP/1.1 implementation. Use variables âdowngrade-1.0â and
âforce-response-1.0â for this.
BrowserMatch âMSIE [2-5]â
nokeepalive ssl-unclean-shutdown
downgrade-1.0 force-response-1.0
Per-Server Logging:
The home of a custom SSL log file. Use this when you want a
compact non-error SSL logfile on a virtual host basis.
CustomLog logs/ssl_request_log
â%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x â%râ %bâ
ServerName www.grahamrmc.com
LogLevel warn
SSL Engine Switch:
SSLEngine on
SSL Cipher Suite:
Server Certificate:
SSLCertificateFile /etc/letsencrypt/live/grahamrmc.com/cert.pem
Server Private Key:
SSLCertificateKeyFile /etc/letsencrypt/live/grahamrmc.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/grahamrmc.com/chain.pem
#SSLVerifyDepth 10
Access Control:
for more details.
SSL Engine Options:
o FakeBasicAuth:
o ExportCertData:
into CGI scripts.
o StdEnvVars:
o StrictRequire:
o OptRenegotiate:
works correctly.
Per-Server Logging:
ServerName grahamrmc.com
LogLevel warn
SSL Engine Switch:
SSLEngine on
SSL Cipher Suite:
Server Certificate:
Server Private Key:
#SSLVerifyDepth 10
Access Control:
for more details.
SSL Engine Options:
o FakeBasicAuth:
o ExportCertData:
into CGI scripts.
o StdEnvVars:
o StrictRequire:
o OptRenegotiate:
works correctly.
Per-Server Logging:
