My domain is: https://aitcloudns.com
I ran the multisite install and works fine, domain mapping all is working fine under WordPress main site.
I have an issue: When you access others domains they are secured but display
https://getyourselfontime.com/
“Not Found
The requested URL / was not found on this server.”
Each domain has getyourselfontime.com.conf & getyourselfontime.com-le-ssl.conf
Server version: Apache/2.4.6 (CentOS 7)
root access: yes, thru terminal
certbot 0.36.0
Question: Where should be pointing this add-on domain, under .conf file is pointing to "DocumentRoot “/var/www/getyourselfontime.com” I’m getting this error because they are pointing a location that doesn’t exist. They should be pointing to the .htaccess settings from the multisite, I’m right?
Thanks for your help!
