I’ve successfully installed a LetsEncrypt certificate for a client server who is now encountering issues with Postbacks on WooCommerce transactions running through WordPress. I have verified that the certificate was installed correctly using SSL Labs.
The error that I receive is as follows:
Error Type: Unable to connect to https://domain.tld
Error Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
This appears to be a Java error, and while I’m not a Java developer, I wasn’t aware that WordPress or WooCommerce had any Java integration.
I’ve done some digging through Google, but I can’t seem to find anything related specifically to this problem. Most of this has to do with Java clients themselves having trouble. Could the payment processor be the cause?
Does anyone know where I could look to debug this issue? A push in the right direction would be much appreciated. Thanks.
EDIT: This is an issue with Java on a postback made to WooCommerce. Their version of Java does not yet support LE (which I’m not sure why, but it’s not something I can fix locally.)
