Hello,
I read the FAQs here and on certbot, nothing about Hostmonster.
I Googled “letsencrypt hostmonster” and “certbot hostmonster” and nothing.
I’ve searched Hostmonster help and nothing on letsencrypt or certbot.
In the drop down list for operating systems on certbot, the only linux is “Arch Linux”, however in my cpanel on hostmonster, it says the operating system is “Linux”. So, I do not know if it would be safe to select “Arch Linux” on certbot.
The help on hostmonster says one must have a dedicated IP address to install SSL/TLS. However, reading on the topic here, it is clearly stated that dedicated IP addresses are no longer needed.
So, I have these questions:
Has anyone gotten a Let’s Encrypt certificate on their Hostmonster account and if so, how did you do it?
Do I need a dedicated IP address to get a Let’s Encrypt certificate?
What do I choose for the operating system on certbot?
I have a main domain “MainDomain.com” and another domain “OtherDomain.com” where “OtherDomain.com” maps to “OtherDomain.MainDomain.com” as a sub domain. I want a certificate for both domains, will a certificate for “MainDomain.com” also cover “OtherDomain.com” or will I need to get another certificate for “OtherDomain.com” as well?
Thank you for your help.
