Wildcard certificates for INWX, shared secret missing
korimort.at
certbot run --authenticator dns-inwx --dns-inwx-credentials /etc/letsencrypt/inwx.cfg --installer nginx -d korimort.at -d "*.korimort.at" -v
Plugins selected: Authenticator dns-inwx, Installer nginx
Requesting a certificate for korimort.at and *.korimort.at
dns-01 challenge for Identifier(typ=IdentifierType(dns), value='korimort.at')
Missing property in credentials configuration file /etc/letsencrypt/inwx.cfg:
  • Property "dns_inwx_shared_secret" not set (should be Optional shared secret code for the two-factor authentication assigned to the INWX API account.).
nginx/1.26.3
Linux version 6.12.75+rpt-rpi-v8 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-14 (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Debian 1:6.12.75-1+rpt1 (2026-03-11)
INWX: https://www.inwx.de/
Yes.
CLI
certbot 5.4.0
my inwx.cfg file looks like this:
dns_inwx_url = https://api.domrobot.com/xmlrpc/
dns_inwx_username = XXXXXXX
dns_inwx_password = YYYYYYY
dns_inwx_shared_secret =
log file output:
2026-03-26 10:07:29,411:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/3153963201/678773151091 HTTP/1.1" 200 393
2026-03-26 10:07:29,411:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 26 Mar 2026 09:07:29 GMT
Content-Length: 393
Boulder-Requester: 3153963201
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: tWo_Kf9RjibLVB5235J0b8RbetItW1htojcoHtddjNN1wDUMMHU
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "korimort.at"
"status": "pending",
"expires": "2026-04-02T08:09:59Z",
"challenges": [
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/3153963201/678773151091/jpMmpQ",
"token": "hbfIAMwgXN_vbPiUKJDfBuF8k8nR-57puQkYQJMd-a8"
"wildcard": true
2026-03-26 10:07:29,412:DEBUG:acme.client:Storing nonce: tWo_Kf9RjibLVB5235J0b8RbetItW1htojcoHtddjNN1wDUMMHU
2026-03-26 10:07:29,412:INFO:certbot._internal.auth_handler:Performing the following challenges:
2026-03-26 10:07:29,413:INFO:certbot._internal.auth_handler:dns-01 challenge for Identifier(typ=IdentifierType(dns), value='korimort.at')
2026-03-26 10:07:29,416:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/auth_handler.py", line 84, in handle_authorizations
resps = self.auth.perform(achalls)
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/plugins/dns_common.py", line 68, in perform
self._setup_credentials()
File "/snap/certbot-dns-inwx/current/lib/python3.12/site-packages/certbot_dns_inwx/_internal/dns_inwx.py", line 60, in _setup_credentials
self.credentials = self._configure_credentials(
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/plugins/dns_common.py", line 199, in _configure_credentials
credentials_configuration.require(required_variables)
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/plugins/dns_common.py", line 309, in require
raise errors.PluginError(
certbot.errors.PluginError: Missing property in credentials configuration file /etc/letsencrypt/inwx.cfg:
2026-03-26 10:07:29,417:DEBUG:certbot._internal.error_handler:Calling registered functions
2026-03-26 10:07:29,417:INFO:certbot._internal.auth_handler:Cleaning up challenges
2026-03-26 10:07:29,417:DEBUG:certbot._internal.log:Exiting abnormally:
File "/snap/certbot/5452/bin/certbot", line 6, in
sys.exit(main())
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/main.py", line 18, in main
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/main.py", line 1886, in main
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/main.py", line 1446, in run
new_lineage = _get_and_save_cert(le_client, config, sans,
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
lineage = le_client.obtain_and_enroll_certificate(sans, certname)
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/client.py", line 533, in obtain_and_enroll_certificate
cert, chain, key, _ = self.obtain_certificate(sans)
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/client.py", line 434, in obtain_certificate
File "/snap/certbot/5452/lib/python3.12/site-packages/certbot/_internal/client.py", line 512, in _get_order_and_authorizations
    2026-03-26 10:07:29,422:ERROR:certbot._internal.log:Missing property in credentials configuration file /etc/letsencrypt/inwx.cfg:
You may need to set that to some (fake) value even with 2FA disabled. See these related reports about that option. If that still does not work you would be better off posting on the github for that inwx plugin. The developers of that would need to address this problem
