How many time i can execute issue command for same certificate. After run same command it reach its limit. please find error below .
what is limit quota to execute issue command. How frequent i can execute this command. Because i don’t want to renew certificate. I need to regenerate each interval.
Create new order error. Le_OrderFinalize not found. {
“type”: “urn:ietf:params:acme:error:rateLimited”,
“detail”: "Error creating new order :: too many certificates already issued for exact set of domains: *.myaddressline.com:
“status”: 429
Yes, i want to issue certificate only not renew in this case should i need to delete old one , or how can i execute issue command only. what is rate limit to issue certificate for same domain by lets encrypt.
You can check your status at https://letsdebug.net/
Enter the FQDN that you want to issue and it will simulate the process and let you know if there is any problem.
I am not facing any issue while creating certificate.
I just need to execute issue command on some interval and upload that certificate to azure api gateway.
i almost did that but failed after few attempts due to rate limit . i just need to know about rate limit how frequent i can execute issue command.
