Wildcard Certificate and auto renew problems
Hi, i create a TXT record in our DNS Entry. But i dont know how to solve this with the Key Value:
@ IN TXT “vIcLnxfIEyJ0L73tEHrs1eQEpHrKpUU-DXPSRpmD4gA”
First time, i want to solve this manually. Later i will so,ve this automatically because i dont want to change every 90 days the keyvalue in the DNS entry. How can i resolve this?
bgcamp.de
certbot -d bgcamp.de --manual --preferred-challenges dns certonly
Failed authorization procedure. bgcamp.de (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.bgcamp.de
Ubuntu 18.04
Hetzner
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.33
Thank you
Hi @usxliberty
checking your domain you have done 50 % correct ( https://check-your-website.server-daten.de/?q=bgcamp.de ):
You have created the correct TXT entry, but the name is wrong.
Compare it with
So add
_acme-challenge
as name, your menu may add the domain. Then
as value. Then recheck your domain. If there is a "looks good" message, it should work.
And you don't have created one of the typical wrong entries (duplicated domain names or _acme-challenge.domainname as value).
