oldgamers.team
DOMAIN=oldgamers.team && ./certbot-auto certonly --manual -d *.$DOMAIN -d $DOMAIN --agree-tos --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory
requested (ref: /etc/letsencrypt/renewal/oldgamers.team.conf)
It contains these names: oldgamers.team
You requested these names for the new certificate: *.oldgamers.team,
oldgamers.team.
certificate?
(E)xpand/©ancel: E
dns-01 challenge for oldgamers.team
Please deploy a DNS TXT record under the name
_acme-challenge.oldgamers.team with the following value:
hoXlZvX6OrxL1nbWTODchQVAMDdI9K8pRRLKls6QH2Y
Before continuing, verify the record is deployed.
Press Enter to Continue
g77v47G9lFZKoxGdziqUhxKE4cC55PYSfC24aIC0J0M
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet. Note that you might be
asked to create multiple distinct TXT records with the same name. This is
permitted by DNS standards.)
Waiting for verificationā¦
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/oldgamers.team/fullchain.pem
/etc/letsencrypt/live/oldgamers.team/privkey.pem
Your cert will expire on 2019-04-25. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again. To non-interactively renew all of your certificates, run
ācertbot-auto renewā -
Donating to ISRG / Letās Encrypt: https://letsencrypt.org/donate
Server version: Apache/2.4.25 (Debian)
Server built: 2018-11-03T18:46:19
Debian 9.7
OVH
I can login to a root shell on my machine (yes or no, or I donāt know):
Yes
Iām using a control panel to manage my site (no, or provide the name and version of the control panel):
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youāre using Certbot):
certbot 0.30.2
The problem Iām having:
Chromium is reporting āNot secureā when I go to forum.oldgamers.team. Everything is fine if I go to oldgamers.team. Iām not sure if it makes a difference, but forum.oldgamers.team is a CNAME to oldgamers.team. I simply want to separate it as a VHOST in apache as I want the forum to be separate from the main web page.
