Whitespace in values under /etc/letsencrypt/cli.ini
What is the correct way to introduce values with spaces in /etc/letsencrypt/cli.ini? What I need is
renew-hook = /usr/bin/php /some/script.php
Is it ok that way or mby some quoting is required?
I think this is already right.
@rg305, the first part should be the PHP interpreter and the second part the script to be interpreted. However, @dandelionred, you can also get around needing to run the interpreter explicitly by making the first line of the script itself be
#!/usr/bin/php
See also
There is a reason why I don’t use shebangs with php as well why I don’t put the whole command into a shell one-liner. Thanks for your reply! I was pretty sure quoting was not required, just needed someone to approve it.
