When prefix by www followed by domain adress it is showing 404 not found
 server_name thebandwala.com www.thebandwala.com;
        root /var/www/thebandwala/client;
        index  index.html index.htm;
        proxy_http_version 1.1;
        proxy_set_header Connection 'upgrade';
        proxy_set_header Host $host;
        proxy_cache_bypass $http_upgrade;
        try_files $uri $uri/ /index.html;
       location /api {
        proxy_pass http://62.72.58.196:8800;
    ssl_certificate /etc/letsencrypt/live/thebandwala.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/thebandwala.com/privkey.pem; # managed by Certbot
         listen 80;
       return 301 https://thebandwala.com$request_uri;
    } # managed by Certbot
Then there is likely some other vhost that is conflicting/overlapping.
Please show the entire web server config:
nginx -T
root@srv420755:~# nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/avif                            avif;
    image/png                             png;
    image/svg+xml                         svg svgz;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/webp                            webp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    font/woff                             woff;
    font/woff2                            woff2;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.oasis.opendocument.graphics        odg;
    application/vnd.oasis.opendocument.presentation    odp;
    application/vnd.oasis.opendocument.spreadsheet     ods;
    application/vnd.oasis.opendocument.text            odt;
    application/vnd.openxmlformats-officedocument.presentationml.presentation    pptx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet    xlsx;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.wap.wmlc              wmlc;
    application/wasm                      wasm;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/thebandwala:
 server_name thebandwala.com www.thebandwala.com *.thebandwala.com;
  location /api {
    if ($host = thebandwala.com) {
    listen 80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
this is showing after nginx -T
OK, I can see is clearer now [that I opened my eyes fully].
The problem is within this vhost:
    listen 80;
I'd change it to this:
     listen 80;
after change it to
listen 80;
still not resolve www.thebandwala.com
certficiate on that server is valid just for non-www version, you will need a new certificate with both names. and it still doesn't redirect though
Did you also reload nginx after that?
What shows?:
certbot certificates
I have systemctl reload nginx ,,,,after that when www.thebandwala.com it shows
404 Not Found
nginx/1.22.0 (Ubuntu
I have no idea how to resolve this error
They said they fixed that per your instructions (their post #6). And, they confirmed reload of nginx.
@paraschouhan15 Can you upload the config.txt file created by the below command? It must be a capital T. Use the upload button on the post menu.
sudo nginx -T >config.txt
Otherwise copy/paste the results (very long) with 3 backticks before and after like:
copy/paste results
