Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is:thebandwala.com
I ran this command:404 not found
It produced this output: when after successful installation, my website not showing and a error showing that 404 not found.
My web server is (include version):ubuntu23 hostinger VPS
The operating system my web server runs on is (include version):Ubuntu23
My hosting provider, if applicable, is:hostinger
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.1.0
if ($host = thebandwala.com) {
} # managed by Certbot
listen 80;
server_name thebandwala.com www.thebandwala.com;
this is in my server code showing
rg305
September 28, 2023, 1:51pm
3
Hi @paraschouhan15 , and welcome to the LE community forum
Your coding fails to redirect the www name:
curl -Ii http://thebandwala.com/
Server: nginx/1.22.0 (Ubuntu)
Date: Thu, 28 Sep 2023 13:49:12 GMT
Content-Type: text/html
Content-Length: 178
curl -Ii http://www.thebandwala.com/
HTTP/1.1 404 Not Found
Date: Thu, 28 Sep 2023 13:49:17 GMT
Content-Length: 162
root /var/www/thebandwala/client;
index index.html index.htm;
proxy_http_version 1.1;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
try_files $uri $uri/ /index.html;
location /api {
proxy_pass http://IP:8800;
ssl_certificate /etc/letsencrypt/live/thebandwala.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/thebandwala.com/privkey.pem; # managed by Certbot
listen 80;
//KINDLY SEE AND CHECK WHERE I HAVE ERROR AND TO CORRECT HOW ??
before ssl installation it was running well but after installation and success of SSL problem created
rg305
September 28, 2023, 2:33pm
6
I don't see the closing "}" in your post.
So, there may be more that you are not showing.
That said, it would be simpler to just show us the entire nginx config:
nginx -T
I have shown all code of nginx kindly check where is error.
and when i throw command nginx -t,,,
rg305
September 28, 2023, 2:44pm
8
No you have not.
All the code is shown with:
nginx -T
Use a capital T not lower case t.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/avif avif;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.wap.wmlc wmlc;
application/wasm wasm;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/thebandwala:
location /api {
listen 80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
rg305
September 28, 2023, 2:57pm
10
Change that to:
listen 80;
return 301 https://thebandwala.com$request_uri;
thank you very for your valuable time, my problem have been resolved,,,,,
