Well known not found
smtp.bluedental.pl
certbot certonly --webroot -w /etc/nginx/token/ -d smtp.bluedental.pl
Failed authorization procedure. smtp.bluedental.pl (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://smtp.bluedental.pl/.well-known/acme-challenge/E0_ZTaN9YfripH2CF8zihBqmNd6N8n-X-PF9iBvRnZQ [37.190.144.15]: “\r\n404 Not Found\r\n<body bgcolor=“white”>\r\n
404 Not Found
\r\n
Debian GNU/Linux 9 (stretch)
certbot 0.28.0
dig smtp.bluedental.pl:
shows proper ip
nginx conf:
listen 80;
server_name smtp.bluedental.pl sss.bluedental.pl;
root /etc/nginx/token/;
That all looks correct.
Are you certain the IP address is correct?
What does Nginx’s error.log show?
If you check the Nginx configuration with “nginx -T”, is the virtual host enabled? Could there be another conflicting one?
Yes I am. 37.190.144.15
It’s weird. Nothing.
Is the virtual host enabled?
After nginx -T I don’t see smtp.bluedental.pl virtual host configuration.
I wrote some bind configuration on another server , but they all pointing to 37.190.144.15, so there should be no conflicts
There must be some name overlap; so that nginx is serving that name from another root.
grep -ERi 'server_name|bluedental.com|_default_' /etc/nginx/
