Well, that is possible however unlikely. May be your IP is not correct? What is the output of the command curl -s 'http://ifconfig.me/' on your Pi?
There does not seem to be any output after putting in that command.
pi@raspberrypi:~ $ sudo curl -s 'http://ifconfig.me/'
pi@raspberrypi:~ $
Try that one: curl -v -s 'https://ifconfig.me/' and curl -v -s 'http://checkip.dyndns.com/'
pi@raspberrypi:~ $ sudo curl -v -s 'https://ifconfig.me/' and curl -v -s 'http://checkip.dyndns.com/'
- Expire in 0 ms for 6 (transfer 0x13fe8a0)
- Expire in 1 ms for 1 (transfer 0x13fe8a0)
- Expire in 0 ms for 1 (transfer 0x13fe8a0)
- Expire in 2 ms for 1 (transfer 0x13fe8a0)
- Expire in 4 ms for 1 (transfer 0x13fe8a0)
- Expire in 3 ms for 1 (transfer 0x13fe8a0)
- Expire in 6 ms for 1 (transfer 0x13fe8a0)
- Trying 34.117.59.81...
- TCP_NODELAY set
- Expire in 200 ms for 4 (transfer 0x13fe8a0)
- Connected to ifconfig.me (34.117.59.81) port 443 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- successfully set certificate verify locations:
- CAfile: none
CApath: /etc/ssl/certs - TLSv1.3 (OUT), TLS handshake, Client hello (1):
- TLSv1.3 (IN), TLS handshake, Server hello (2):
- TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
- TLSv1.3 (IN), TLS handshake, Certificate (11):
- TLSv1.3 (IN), TLS handshake, CERT verify (15):
- TLSv1.3 (IN), TLS handshake, Finished (20):
- TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
- TLSv1.3 (OUT), TLS handshake, Finished (20):
- SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
- ALPN, server accepted to use h2
- Server certificate:
- subject: CN=ifconfig.me
- start date: May 1 06:09:29 2021 GMT
- expire date: Jul 30 07:09:29 2021 GMT
- subjectAltName: host "ifconfig.me" matched cert's "ifconfig.me"
- issuer: C=US; O=Google Trust Services LLC; CN=GTS CA 1D4
- SSL certificate verify ok.
- Using HTTP2, server supports multi-use
- Connection state changed (HTTP/2 confirmed)
- Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
- Using Stream ID: 1 (easy handle 0x13fe8a0)
GET / HTTP/2
Host: ifconfig.me
User-Agent: curl/7.64.0
Accept: /
- TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
- old SSL session ID is stale, removing
- Connection state changed (MAX_CONCURRENT_STREAMS == 100)!
< HTTP/2 200
< access-control-allow-origin: *
< content-type: text/plain; charset=utf-8
< content-length: 12
< date: Sun, 23 May 2021 17:19:44 GMT
< x-envoy-upstream-service-time: 1
< via: 1.1 google
< alt-svc: clear
< - Connection #0 to host ifconfig.me left intact
47.184.10.80* Expire in 0 ms for 6 (transfer 0x13fe8a0) - Expire in 1 ms for 1 (transfer 0x13fe8a0)
- Could not resolve host: and
- Closing connection 1
- Could not resolve host: curl
- Closing connection 2
- Trying 162.88.193.70...
- TCP_NODELAY set
- Expire in 149994 ms for 3 (transfer 0x13fe8a0)
- Connected to checkip.dyndns.com (162.88.193.70) port 80 (#3)
GET / HTTP/1.1
Host: checkip.dyndns.com
Accept: /
< HTTP/1.1 200 OK
< Content-Type: text/html
< Server: DynDNS-CheckIP/1.0.1
< Connection: close
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Length: 104
One moment my gateway IP is not set.
You should also port forward port 443.
You shouldn't put both curl commands on the same line with 'and' in between, but execute them separate.
Sorry one moment. Let me get both of those commands in correctly.
Here is
pi@raspberrypi:~ $ curl -v -s 'http://checkip.dyndns.com/'
- Expire in 0 ms for 6 (transfer 0x1bbf8a0)
- Expire in 1 ms for 1 (transfer 0x1bbf8a0)
- Expire in 0 ms for 1 (transfer 0x1bbf8a0)
- Expire in 2 ms for 1 (transfer 0x1bbf8a0)
- Expire in 4 ms for 1 (transfer 0x1bbf8a0)
- Expire in 3 ms for 1 (transfer 0x1bbf8a0)
- Expire in 5 ms for 1 (transfer 0x1bbf8a0)
- Trying 216.146.43.71...
- TCP_NODELAY set
- Expire in 149991 ms for 3 (transfer 0x1bbf8a0)
- Expire in 200 ms for 4 (transfer 0x1bbf8a0)
- Connected to checkip.dyndns.com (216.146.43.71) port 80 (#0)
GET / HTTP/1.1
Accept: /
< HTTP/1.1 200 OK
< Connection: close
< Pragma: no-cache
Here is
- Expire in 0 ms for 6 (transfer 0x125f8a0)
- Expire in 1 ms for 1 (transfer 0x125f8a0)
- Expire in 0 ms for 1 (transfer 0x125f8a0)
- Expire in 2 ms for 1 (transfer 0x125f8a0)
- Expire in 4 ms for 1 (transfer 0x125f8a0)
- Expire in 3 ms for 1 (transfer 0x125f8a0)
- TCP_NODELAY set
- Expire in 149995 ms for 3 (transfer 0x125f8a0)
- Expire in 200 ms for 4 (transfer 0x125f8a0)
- Connected to checkip.dyndns.com (162.88.193.70) port 80 (#0)
GET / HTTP/1.1
Accept: /
< HTTP/1.1 200 OK
< Connection: close
< Pragma: no-cache
I will go ahead and port forward on 443 also
So your IP is correct, it is matching:
pi@raspberrypi:~ $ host newkiddintown.com
newkiddintown.com has address 47.184.10.80
pi@raspberrypi:~ $
Please do the forwarding of port 443 on your DSL device to your Pi.
Port 443 is now forwarding to the Pi.
Your site now works perfectly.
All looks good now:
pi@raspberrypi:~ $ openssl s_client -connect newkiddintown.com:443 -servername newkiddintown.com
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = newkiddintown.com
verify return:1
Certificate chain
0 s:CN = newkiddintown.com
2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3
BOYS THANKS! Couldnt be more happy right now. I was 5 minutes away from blowing this raspberry pi out of the water
Look how great a site that is!
I feel very dumb that the only reason it wasnt working was because port 443 wasnt implemented... It seemed like a much bigger complex issue...
Anyways much appreciated team for the help.
All the best wishes!
