Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: www.benjaminthompson.org
I ran this command: sudo certbot --apache -d benjaminthompson.org
It produced this output: Index of /
My web server is (include version): Apache 2.4.1.8
The operating system my web server runs on is (include version):Ubuntu 16.04
My hosting provider, if applicable, is: digitalocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): SSH
This site could not prove it’s www.benjaminthompson.org beacuse the certificate is given to benjaminthompson.org
how do I change certificate domain to www.benjaminthompson.org ?
Please help, I’m desperate.
You must specify all valid domain names on certificate issuance.
You can redo your certificate:
sudo certbot --apache --cert-name benjaminthompson.org -d benjaminthompson.org -d www.benjaminthompson.org
Thank you so much! :)))))
So I updated the certificate and now I’m running into another issue.
Please have a look: www.benjaminthompson.org
tp:/
Certicat: NET::ERR_CERT_AUTHORITY_INVALID
I don’t see any error here. Could you please close all instances of your browser and then retry?
Sorry about the confusion.
When I enter benjaminthompson.org I get the error: Certicat: NET::ERR_CERT_AUTHORITY_INVALID
When I enter www.benjaminthompson.org it enters HTTP which should be HTTPS
Thanks
Earlier I used your link: sudo certbot --apache --cert-name benjaminthompson.org -d benjaminthompson.org -d www.benjaminthompson.org
I have now changed it:
sudo certbot --apache --cert-name benjaminthompson.org -d www.benjaminthompson.org
I Hope it will resolv the issue.
Unfortunately it didn’t work.
All help is really appreciated.
/etc/apache2/sites-available/benjaminthompson.org.conf
<VirtualHost *:80>
ServerName benjaminthompson.org
DocumentRoot /var/www/
RewriteEngine on
RewriteCond %{SERVER_NAME} =benjaminthompson.org
<VirtualHost *:80>
ServerName www.benjaminthompson.org
Redirect permanent / http://benjaminthompson.org/
RewriteEngine on
RewriteCond %{SERVER_NAME} =benjaminthompson.org [OR]
RewriteCond %{SERVER_NAME} =www.benjaminthompson.org
what nameservers should be listed in /etc/resolv.conf ?
How do I troubleshoot my problem?
Thanks
ahaw021
December 20, 2017, 11:32pm
12
clear your browser and try with another one
your certificate is working
Hi alhaw021,
I know, thanks.
My problem is my page don’t display the content from my page.
ahaw021
December 20, 2017, 11:36pm
14
thats a web development problem not a HTTPS / SSL problem
stackexchange is the place to ask those questions
I have the same problem that My problem is my website don’t display the content from my page. My web : https://standaviet.vn
Make sure your document root is set to /var/www/html in your virtual host file
If you have wordpress or else in the correct folder
system
Closed
February 1, 2018, 11:34pm
18
