Website can't be reached anymore even with temporarily disabled firewall and certificate is invalid somehow! Seriously please help!
All of the heetinc.net and www.heetinc.net requests work for me right now.
It seems extra complicated to have one system (ghs) handling redirects for heetinc.net yet have an nginx server handling www.heetinc.net
But, it's your system you can do as you like :slight_smile:
curl -Ii www.heetinc.net
Server: nginx/1.22.1
Date: Tue, 28 Feb 2023 19:01:13 GMT
Content-Type: text/html
Content-Length: 169
$ nmap -Pn heetinc.net
Starting Nmap 7.80 ( https://nmap.org ) at 2023-02-28 19:00 UTC
Nmap scan report for heetinc.net (216.239.34.21)
Host is up (0.015s latency).
Other addresses for heetinc.net (not scanned): 216.239.36.21 216.239.32.21 216.239.38.21 2001:4860:4802:36::15 2001:4860:4802:38::15 2001:4860:4802:32::15 2001:4860:4802:34::15
rDNS record for 216.239.34.21: any-in-2215.1e100.net
Not shown: 998 filtered ports
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 4.03 seconds
$ nmap -Pn www.heetinc.net
Starting Nmap 7.80 ( https://nmap.org ) at 2023-02-28 19:01 UTC
Nmap scan report for www.heetinc.net (83.179.80.74)
Host is up (0.21s latency).
rDNS record for 83.179.80.74: m83-179-80-74.cust.tele2.lt
Not shown: 978 filtered ports
PORT      STATE SERVICE
22/tcp    open  ssh
80/tcp    open  http
254/tcp   open  unknown
416/tcp   open  silverplatter
443/tcp   open  https
900/tcp   open  omginitialrefs
990/tcp   open  ftps
1089/tcp  open  ff-annunc
2003/tcp  open  finger
3300/tcp  open  ceph
3389/tcp  open  ms-wbt-server
4567/tcp  open  tram
5911/tcp  open  cpdlc
7001/tcp  open  afs3-callback
7402/tcp  open  rtps-dd-mt
7496/tcp  open  unknown
8083/tcp  open  us-srv
8649/tcp  open  unknown
9944/tcp  open  unknown
16018/tcp open  unknown
50002/tcp open  iiimsf
64680/tcp open  unknown
Nmap done: 1 IP address (1 host up) scanned in 164.33 seconds
You can stay clear of heetinc.net
Focus only on the "www":
Addresses: 2001:4860:4802:36::15
           216.239.32.21
           216.239.36.21
           216.239.38.21
           216.239.34.21
Address: 83.179.80.74
And now this is what I see.
My computer must have had A Momentary Lapse of Reason while Learning to Fly :slight_smile:
$ curl -Ii http://heetinc.net
HTTP/1.1 302 Found
Date: Tue, 28 Feb 2023 19:05:13 GMT
Server: ghs
Content-Length: 221
X-XSS-Protection: 0
X-Frame-Options: SAMEORIGIN
$ curl -Ii https://heetinc.net
HTTP/2 302
date: Tue, 28 Feb 2023 19:05:17 GMT
content-type: text/html; charset=UTF-8
server: ghs
content-length: 221
x-xss-protection: 0
x-frame-options: SAMEORIGIN
$ curl -Ii http://www.heetinc.net
Date: Tue, 28 Feb 2023 19:05:24 GMT
Content-Length: 169
$ curl -Ii https://www.heetinc.net
HTTP/2 200
server: nginx/1.22.1
date: Tue, 28 Feb 2023 19:05:30 GMT
vary: Accept-Encoding
x-powered-by: PHP/8.2.3
strict-transport-security: max-age=63072000
Will do! :beer:
Congratulations, you're SSLLabs-ing Google.
That has a Let's Encrypt issued certificate Alternative names heetinc.net
vs this certificate Alternative names heetinc.net www.heetinc.net
No, it's a cert from "GTS CA 1D4". Not Let's Encrypt. It's hosted by Google. Not OP.
Yep! My bad.
Anyway, it seems a HTTP to HTTPS redirect for www.heetinc.net is currently also in effect, so all good I guess.
Thanks, everyone! I got it to work, thanks to everyone's help! No matter what you type, if it's http or https or www or not, it will redirect you to the website without using 2 separate systems to handle redirects! One issue, I used to be able to enter the phpmyadmin page through localhost/phpmyadmin. Now I can't anymore! If you need to see the configuration for NGINX, it's here! I also want to know if it's normal I can't enter my website through a private IPv4 address without using https://, because I used to be able to, and if it's usual to have my localhost IP address change to ::1!
::1 == localhost, just IPv6 instead of IPv4.
Alright, everything is fixed. Thanks, everyone! I did nothing to solve the certificate is invalid issue... I just had to wait! But there were still a couple of issues that I had to fix! Like using multiple systems handling redirect, phpMyAdmin not opening up anymore, and getting a false GET 404 error! I fixed phpMyAdmin by removing the root directive and adding phpMyAdmin to try_files like this: try_files $uri $uri/ /phpMyAdmin/index.php?$args; Next, the false GET 404 error was fixed by replacing the /scripts in the SCRIPT_FILENAME argument to $document_root like this: fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
Hope you have a fantastic day!
