My domain is: asm-demo.acemcbohol.ph
I ran this command: sudo certbot --nginx -d asm-demo.acemcbohol.ph www.asm-demo.acemcbohol.ph
It produced this output: Successfully received certificate.
Certificate is saved at: /etc/letsencrypt/live/asm-demo.acemcbohol.ph/fullchain.pem
Key is saved at: /etc/letsencrypt/live/asm-demo.acemcbohol.ph/privkey.pem
This certificate expires on 2022-12-10.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for asm-demo.acemcbohol.ph to /etc/nginx/sites-enabled/asm-demo.acemcbohol.ph
Successfully deployed certificate for www.asm-demo.acemcbohol.ph to /etc/nginx/sites-enabled/asm-demo.acemcbohol.ph
Congratulations! You have successfully enabled HTTPS on https://asm-demo.acemcbohol.ph and https://www.asm-demo.acemcbohol.ph
My web server is (include version): nginx version: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version):Ubuntu 22.04 LTS
or certbot-auto --version
if you're using Certbot):
