So! Hello everyone, I have a problem after ssl installing, the web seems to not find its directory, using nginx.
My domain is: purplenode.lv
I ran this command: Installed ssl.
It produced this output: Of not being able to log in the web.
My web server is (include version): Nginx
The operating system my web server runs on is (include version):ubuntu 16.04
My hosting provider, if applicable, is:Contabo
or certbot-auto --version
if you’re using Certbot):certbot 0.31.0
Download to the config: https://drive.google.com/open?id=1F5-KSPBlrH8Y-z941AcYjmt8v1tU2Gw0
Hi @Gustavs
that's not a command. Please share the command you have used.
Checking your domain there is one new certificate - https://check-your-website.server-daten.de/?q=purplenode.lv#ct-logs
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let's Encrypt Authority X3
2019-10-24
2020-01-22
panel.purplenode.lv, purplenode.lv - 2 entries
duplicate nr. 1
But your domain is invisible, only ConnectFailures. No port 80, no port 443.
And your config file is wrong, there are three
server_name purplenode.lv
only one is allowed. And you have a redirect to https in one 443 - block.
Looks like you have merged different results in one file.
I have ran this command 1. sudo apt-get install certbot python-certbot-nginx, could you please edit the config file? I’m not really smart in these things.
rg305
October 25, 2019, 8:39am
4
server_name purplenode.lv;
root /var/www/html;
index index.html index.htm index.php;
charset utf-8;
try_files $uri $uri/ /index.php?$query_string =404;
location = /favicon.ico { access_log off; log_not_found off; }
location = /robots.txt { access_log off; log_not_found off; }
access_log off;
# allow larger file uploads and longer script runtimes
client_max_body_size 100m;
client_body_timeout 120s;
sendfile off;
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/run/php/php7.2-fpm.sock;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param PHP_VALUE "upload_max_filesize = 100M \n post_max_size=100M";
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param HTTP_PROXY "";
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
fastcgi_connect_timeout 300;
fastcgi_send_timeout 300;
fastcgi_read_timeout 300;
location ~ /\.ht {
deny all;
listen [::]:443 ssl; # ? ? ? IF YOU HAVE IPv6
ssl_certificate /etc/letsencrypt/live/purplenode.lv/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/purplenode.lv/privkey.pem; # managed by Certbot
Now your site works. http and https.
https://purplenode.lv/
If I do purplenode.lv, it doesn’t direct me to the web, earlier it did, before ssl.
Thank you, I will give it a shot, I’ll let you know what happens afterwards.
@rg305 My web works, however, it won’t redirect to the right place, if you do purplenode.lv right now, it won’t show the web, only if you do https://purplenode.lv
Also, when I attempt to log in, afterwards it again shows the error 404.
rg305
October 25, 2019, 9:07am
10
please show the main config file (and any other config files)
Gustavs
October 25, 2019, 9:11am
11
rg305
October 25, 2019, 9:16am
12
Please show:
ls -l /etc/nginx/conf.d/*.conf
ls -l /etc/nginx/sites-enabled/*
Gustavs
October 25, 2019, 9:18am
13
@rg305 https://a.cockfile.com/1P7wA4.png the “default” is the one i sent you earlier, the first one, the pterodactyl all works. panel.purplenode.lv
rg305
October 25, 2019, 9:23am
14
Please show:
sudo ls -l /etc/nginx/conf.d/
show whichever file you haven’t already shown from:
/etc/nginx/sites-enabled/default
/etc/nginx/sites-enabled/pterodactyl.conf
Gustavs
October 25, 2019, 9:24am
15
Conf.d is completely empty. https://a.cockfile.com/V280uP.conf the pterodactyl
rg305
October 25, 2019, 9:26am
16
ok append this to end of the default file:
if ($host = purplenode.lv) {
} # managed by Certbot
listen 80;
that should fix the redirection from http to https
try this for the login problem:
change (the order):
index index.php index.html index.htm;
rg305
October 25, 2019, 9:34am
18
more like this:
root /var/www/html;
charset utf-8;
}#location
access_log off;
sendfile off;
location ~ \.php$ {
}#location
location ~ /\.ht {
deny all;
}#location
}#server
listen 443;
listen [::]:443;
root /var/www/html;
index index.php;
try_files $uri $uri/ =404;
}#location
}#server
listen 443;
}#server
listen 80;
}#server
rg305
October 25, 2019, 9:39am
20
you have two extra “}” at the bottom
must be removed to keep balance “{” with “}”
