Hi all,
searched a lot but did not figure out the reason. I had a https webserver running on my local mac-mini with no noticeable issue months ago, using certbot. But now the same https-web was blocked by Chrome (not secure) and was warned 'weak encryption' by Firefox. (check demo: https://wklytics.com)
The webserver is python twisted, with hostname purchased from no-ip.com (who told me issue is not on their side..). Checked and searched twisted python script, it is using default openssl (not sure this will be the issue or not). Hope some experts could help.
------- standard questions -------------------------
certbot: started a year ago with no issue,
'certbot certonly --webroot -w xxpath -d wklytics.com'
'certbot renew': shows the current cert is still good -
Webserver, python twisted webserver (python 2.7), keycode:
sslContext = ssl.DefaultOpenSSLContextFactory( self.config['https']['ssl_key'], # Private Key from certbot self.config['https']['ssl_cert'] # Certificate from certbot ) https_factory = Site(https_root) reactor.listenSSL(self.config['https']['port'],https_factory, sslContext); reactor.run()
It showed 'weak encryption connection is not secure' in Firefox and blocked in Chrome (i.e. https://wklytics.com). Strangely, this issue was not there when it was started.
python 2.7.14, twisted 19:10.0
mac-mini: macOS 10.10.5
Hosting on my local mac (I purchase domain name from no-ip.com)
bash (python script to run web server)
or certbot-auto --version
if you're using Certbot):
0.26.1
