I want to use Vultr - one-click WordPress Application for my site - https://www.techprevue.com
I have installed a test website and installed ssl through Vultr docs - https://www.vultr.com/docs/install-lets-encrypt-ssl-on-one-click-wordpress-app
SSL over test site has been installed successfully and I have tried certbot renew dry run (certbot renew --dry-run) that is working properly.
But how can I be assure Let’s Encrypt ceritificate will be auto-renewed on time?
Please help!
edit /etc/letsencrypt/reneal/yourdomain.conf and add
renew_before_expiry = 90 days
and run certbot renew (without --dry-run ) and see if webserver uses new cert.
and remove renew_before_expiry back
Thanks I will check it shortly and let you know. Thanks for kind consideration.
It said no such directory exists
I also tried renewal instead of reneal
schoen
March 20, 2019, 8:37pm
5
Do you have an /etc/letsencrypt
directory?
(It should indeed be /etc/letsencrypt/renewal
rather than reneal
I am new to vultr. I need to check.
If not what to do. Please let me know the steps.
Yes, both directories exist. What should I do now?
In domain.conf these lines found…
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/domain
cert = /etc/letsencrypt/live/domain/cert.pem
privkey = /etc/letsencrypt/live/domain/privkey.pem
chain = /etc/letsencrypt/live/domain/chain.pem
fullchain = /etc/letsencrypt/live/domain/fullchain.pem
[renewalparams]
account = 52***********************************************
installer = nginx
authenticator = nginx
Need help. No body here to answer me.
Hi @vinayprajapati
your site has a Comodo certificate ( https://check-your-website.server-daten.de/?q=techprevue.com ):
CN=techprevue.com, OU=PositiveSSL, OU=Domain Control Validated
15.03.2017
15.03.2020
expires in 358 days techprevue.com, www.techprevue.com - 2 entries
You have a lot of Letsencrypt certificates with subdomains, but not with your main domain. Check the list of your Certificate-Log - entries ( https://check-your-website.server-daten.de/?q=techprevue.com#ct-logs ).
So first complete the tutorial to create a new certificate and install it.
Certbot should create a job to do that. But that doesn't work if you use only --dry-run
I have not yet installed letsencrypt ssl on www.techprevue.com . I m moving this site to vultr and need to setup auto renewal so set up a demo site to check the auto renewal process before migration.
I have completed most of the steps given in various tutorials but how to check if auto renewal will be done before time or not.
That's not required.
If you can create a new certificate, renew works too.
"Renew" creates a new certificate and uses the same parameters of the last certificate.
So this isn't a problem.
"Renew" doesn't mean: "Change the current certificate".
Sir, do you mean, it will be auto renewed?
vinayprajapati:
I don't know, I do not know what you have installed. You have a lot of Letsencrypt certificates ( https://check-your-website.server-daten.de/?q=techprevue.com )
Last Certificates - Certificate Transparency Log Check (BETA)
CRT-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
1200271241
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
2019-02-13 12:59:26
2019-05-14 11:59:26
demo.techprevue.com
no duplicate
1198592920
2019-02-12 15:41:29
2019-05-13 14:41:29
hi.techprevue.com , www.hi.techprevue.com
no duplicate
1029960076
2018-12-14 21:34:53
2019-03-14 21:34:53
demo.techprevue.com
no duplicate
1026978162
2018-12-13 15:48:43
2019-03-13 15:48:43
no duplicate
862956002
2018-10-15 04:56:03
2019-01-13 05:56:03
demo.techprevue.com
no duplicate
857498857
2018-10-13 14:31:58
2019-01-11 15:31:58
no duplicate
744634451
2018-08-15 13:23:04
2018-11-13 14:23:04
demo.techprevue.com
no duplicate
755560717
2018-08-13 13:46:08
2018-11-11 14:46:08
no duplicate
538744046
2018-06-15 21:58:35
2018-09-13 21:58:35
demo.techprevue.com
no duplicate
525399525
2018-06-13 05:55:25
2018-09-11 05:55:25
no duplicate
407039836
2018-04-16 06:20:49
2018-07-15 06:20:49
demo.techprevue.com
no duplicate
330845524
2018-02-14 15:46:49
2018-05-15 14:46:49
demo.techprevue.com
no duplicate
And you have always 30 days to check that and to renew the certificate manual.
So start to use it.
system
Closed
April 24, 2019, 8:01pm
14
