VirtualHost overlap on port 443 localhost.localdomain
Ok misunderstanding. I renamed the file back.
I shall rinse and repeat…try again
Wow Ok… That worked this is what I get now. its Getting closer.
Thanks for your help btw. its awesome…
https://deepmatrix.net is loading its correct homepage.
BUT https://pixpile.com is also loading the deepmatrix.net homepage
So are the other 2 domains.
I’m thinking I need to add the pixpile.com to the custom /etc/zpanel/configs/apache/zpanel-ssl-vhost.conf
See what you got first:
grep -ri pixpile.com /etc/zpanel/configs
/etc/zpanel/configs/apache/httpd-vhosts.conf:# DOMAIN: pixpile.com
/etc/zpanel/configs/apache/httpd-vhosts.conf:ServerName pixpile.com
/etc/zpanel/configs/apache/httpd-vhosts.conf:ServerAlias pixpile.com www.pixpile.com
/etc/zpanel/configs/apache/httpd-vhosts.conf:DocumentRoot “/var/zpanel/hostdata/zadmin/public_html/pixpile_com”
/etc/zpanel/configs/apache/httpd-vhosts.conf:php_admin_value open_basedir “/var/zpanel/hostdata/zadmin/public_html/pixpile_com:/var/zpanel/temp/”
/etc/zpanel/configs/apache/httpd-vhosts.conf:ErrorLog “/var/zpanel/logs/domains/zadmin/pixpile.com-error.log”
/etc/zpanel/configs/apache/httpd-vhosts.conf:CustomLog “/var/zpanel/logs/domains/zadmin/pixpile.com-access.log” combined
/etc/zpanel/configs/apache/httpd-vhosts.conf:CustomLog “/var/zpanel/logs/domains/zadmin/pixpile.com-bandwidth.log” common
/etc/zpanel/configs/apache/httpd-vhosts.conf:# END DOMAIN: pixpile.com
/etc/zpanel/configs/bind/etc/named.conf:zone “pixpile.com” IN {
/etc/zpanel/configs/bind/etc/named.conf: file “/etc/zpanel/configs/bind/zones/pixpile.com.txt”;
/etc/zpanel/configs/bind/zones/pixpile.com.txt:@ IN SOA ns1.pixpile.com. postmaster.pixpile.com. (
/etc/zpanel/configs/bind/zones/pixpile.com.txt:@ 86400 IN MX 10 mail.pixpile.com.
/etc/zpanel/configs/bind/zones/pixpile.com.txt:@ 172800 IN NS ns1.pixpile.com.
/etc/zpanel/configs/bind/zones/pixpile.com.txt:@ 172800 IN NS ns2.pixpile.com.
/etc/zpanel/configs/bind/zones/foxtion.com.txt:@ 172800 IN NS ns1.pixpile.com.
/etc/zpanel/configs/bind/zones/foxtion.com.txt:@ 172800 IN NS ns2.pixpile.com.
It already exists here:
I think the zpanel-ssl-vhost.conf may just be for the zpanel itself.
Or
It is for all the ssl sites - can't tell from where I'm sitting...
This file is auto generated by zpanel and is rewritten when you make changes in the panel . there is only 80 not 443 for pixpile or the other domains
Ive read every where don't touch that file.
That's why i created /etc/zpanel/configs/apache/zpanel-ssl-vhost.conf and used it as an Include
in /etc/zpanel/configs/apache/httpd.conf
OK, show:
grep -r 443 /etc/zpanel/configs
/etc/zpanel/configs/apache/zpanel-ssl-vhost.conf:<virtualhost *:443>
/etc/zpanel/configs/roundcube/main.inc.php:// set the port for the ssl connection as value of this option if it differs from the default 443
perfect, then just modify
to include additional vhost configs (to cover all the other different sites)
Ok. I will do that and then update the post with the results.
Added pixpile.com to /etc/zpanel/configs/apache/zpanel-ssl-vhost.conf
restarted apache and it failed.
service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [Fri Nov 10 14:30:40 2017] [warn] default VirtualHost overlap on port 443, the first has precedence
[FAILED]
Ive read in the forums here to be each domain in a separate file.
Not sure why that would be required.
You are mixing control panel configuration files with user-defined configuration files. This is always a mess and the reason you are shooting yourself into the foot.
lol. bang bang...
Anyone who uses letsEncrypt and Zpanel now called Sentora will have the same problem.
the /etc/zpanel/configs/apache/httpd.conf
has an include for the zpanel generated
nano /etc/zpanel/configs/apache/httpd.conf
# ZPanel Apache Include file for CentOS Linux
# Written by Bobby Allen, 15/05/2011
# Set the Zpanel Alias (used for development, sable will eventually use a VHOST)
Alias /zpanel /etc/zpanel/panel
# Setup the directory settings and PHP security flags for the Zpanel application directory.
<Directory /etc/zpanel/panel>
        Options FollowSymLinks
        AllowOverride All
        DirectoryIndex index.php
        <IfModule mod_php5.c>
                AddType application/x-httpd-php .php
                php_flag magic_quotes_gpc Off
                php_flag track_vars On
                php_flag register_globals Off
                php_admin_value upload_tmp_dir /etc/zpanel/temp
        </IfModule>
</Directory>
# Disallow web access to directories that don't need it/that we don't want people looking in!
<Directory /etc/zpanel/panel/cnf>
    Order Deny,Allow
    Deny from All
</Directory>
# Set server tokens (security??)
ServerTokens Maj
# Now we include the generic VHOST configuration file that holds all the ZPanel user hosted vhost data
Include /etc/zpanel/configs/apache/httpd-vhosts.conf
#CUSTOM SSL LetsEncrypt CONFIGURATION
Include /etc/zpanel/configs/apache/zpanel-ssl-vhost.conf
I have the solution for Zpanel /Sentora.
It took more than a week. help from here.
Installing letsEncrypt to work with Zpanel was ridiculously simple.
It will work with one certificate with child domains and/or
Separate domain certificates.
It may be a simple solution for other situations as well.
I will write a quick instructional guide in a new post.
Add the link here…
Ive written a step by step and posted here on the Forum.
Thanks all for your help.
