/etc/letsencrypt/live/examaker.com/fullchain.pem (skipped)
No renewals were attempted.
My web server is (include version):Apache
Debian 8
My hosting provider, if applicable, is: Contabo.com
Yes
VestaCP
There was a cert issued a month ago but that is not the one being served (that one expires in 8 days).
The system has the newer cert so “Cert not yet due for renewal” is a valid response.
The problem is in why the VestaCP isn’t using the latest cert.
I’m not familiar with that control panel, do you see any way to pick which cert is being used?
I also updated the thread topic to better reflect the problem and attract potential helpers.
For example, maybe VestaCP made a copy of the old certificate and you’ll have to tell it to import the new one as well. You can access the new files via /etc/letsencrypt/live/examaker.com (probably you want fullchain.pem and privkey.pem). As @rg305 says, your certificate has already been renewed and the new certificate which should be present there (but apparently not noticed by VestaCP?) will be valid until January 12.
