I'm working on a certificate management API that will use the python library of certbot to generate certificates. The code still worked on friday but today nothing seems to work anymore. I already saw a thread with a similar issue but it seems like the only solution is to fork the repo. Isn't there a quicker fix to this problem? I can"t seem to find a reason why my program is throwing a ValueError. The error seems to begin when the http01 challenge starts. How can i get around this? Thanks in advance.
example.certiman.inuits.dev
whoami.certiman.inuits.dev
import certbot.main
from loguru import logger
class AcmeClient:
def __init__(self, email, staging=False):
self.email = email
self.staging = staging
def generate_cert(self, domain):
args = ["certonly",
"--standalone",
"--agree-tos",
"-n",
"--email", self.email,
"-d", f"{domain}.certiman.inuits.dev",
"-v"
if self.staging:
args.append("--staging")
certbot.main.main(args)
class CertGenerator:
def __init__(self, domains_file):
self.domains_file = domains_file
def generate_certs(self):
with open(self.domains_file) as f:
for line in f:
domain = line.rstrip('\n')
client = AcmeClient(email='andreo@inuits.eu', staging=True)
logger.info(f"Generating certificate for {domain}")
client.generate_cert(domain)
try:
except ValueError as e:
logger.critical(f"{e} for {domain}")
continue
# ValueError
ValueError: signal only works in main thread of the main interpreter
## Traceback (most recent call last)
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 2551, in __call__
return self.wsgi_app(environ, start_response)
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 2531, in wsgi_app
response = self.handle_exception(e)
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 2528, in wsgi_app
response = self.full_dispatch_request()
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 1825, in full_dispatch_request
rv = self.handle_user_exception(e)
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
*** #### File "/usr/local/lib/python3.9/site-packages/flask/app.py", line 1799, in dispatch_request
**return self.ensure_sync(self.view_functions[rule.endpoint])(view_args)
*** #### File "/api/main.py", line 33, in generate_certs
return generate_certificates()
*** #### File "/api/api.py", line 51, in generate_certificates
cg.generate_certs()
*** #### File "/api/acmeclient.py", line 34, in generate_certs
*** #### File "/api/acmeclient.py", line 21, in generate_cert
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/main.py", line 19, in main
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/main.py", line 1864, in main
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/main.py", line 1597, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/main.py", line 141, in _get_and_save_cert
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/client.py", line 516, in obtain_and_enroll_certificate
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/client.py", line 428, in obtain_certificate
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/auth_handler.py", line 85, in handle_authorizations
with error_handler.ExitHandler(self._cleanup_challenges, achalls):
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/error_handler.py", line 91, in __enter__
self._set_signal_handlers()
*** #### File "/usr/local/lib/python3.9/site-packages/certbot/_internal/error_handler.py", line 143, in _set_signal_handlers
signal.signal(signum, self._signal_handler)
*** #### File "/usr/local/lib/python3.9/signal.py", line 56, in signal
handler = _signal.signal(_enum_to_int(signalnum), _enum_to_int(handler))
Werkzeug/2.2.3
Linux Mint Cinnamon 21
i don't know
no
or certbot-auto --version
if you're using Certbot):
2.5.0
