INFO com.akamai.cps.businesscase.BusinessCaseServiceImpl - Not sending duplicate message CA_ORDER_ERROR, E: Order’s status (“invalid”) is not acceptable for finalization, W:null for Job JobID(id=1001856).
LeErrorReport(statusCode=403, type=urn:ietf:params:acme:error:orderNotReady, detail=Order’s status (“invalid”) is not acceptable for finalization)
Authoritative name servers must support TCP connections. And the Echo Capitalization check must work, that's a fatal error -> Unbound reports a Servfail.
Please update your name servers or change your dns provider.
When an order is invalid it means one of the order authorization's failed a domain validation challenge. Your system should retrieve each of the authorizations associated with the order and display the problem details to the user directly. That would help clarify why this is happening and how to fix it and is something you could implement entirely on your end.
