Uwsgi_pass not working after certbot success (docker-compose)
Sorry if I answer any of the questions below inaccurately...
My domain is: geodraw.org
I ran this command: certbot --nginx
It produced this output: Success
My web server is (include version): not sure
The operating system my web server runs on is (include version): Ubuntu 16.04.7 LTS but I am running nginx in the container nginx:1.20-alpine
My hosting provider, if applicable, is: Google Cloud Platform
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.11.0
Before using certbot everything was working well. Now, connections are refused. After using certbot it seems that user requests are not being passed by uwsgi_pass to the other docker containers. I am pretty sure about this because I can see that I'm reaching nginx with requests but not the other containers from the docker-compose logs. I've pasted relevant files down below. THANK YOU <3 :grinning: :smiley: :robot:
/etc/nginx/conf.d/nginx.conf
server_name geodraw.org www.geodraw.org;
    include uwsgi_params;
    uwsgi_pass front:8081;
location /api {
    uwsgi_pass flask:8080;
ssl_certificate /etc/letsencrypt/live/geodraw.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/geodraw.org/privkey.pem; # managed by Certbot
if ($host = www.geodraw.org) {
} # managed by Certbot
if ($host = geodraw.org) {
listen 80;
listen [::]:80;
cat /etc/nginx/nginx.conf
user nginx;
worker_processes auto;
error_log /var/log/nginx/error.log notice;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                  '$status $body_bytes_sent "$http_referer" '
                  '"$http_user_agent" "$http_x_forwarded_for"';
access_log  /var/log/nginx/access.log  main;
sendfile        on;
#tcp_nopush     on;
keepalive_timeout  65;
#gzip  on;
docker-compose.yml
version: "3.7"
services:
flask:
    image: flask
    build: ./flask
    container_name: flask
    restart: always
    environment:
        - APP_NAME=MyFlaskApp
    expose:
        - 8080
front:
    image: front
    build: ./front
    container_name: front
    restart: always
    environment:
    expose:
        - 8081
nginx:
    image: nginx
    build: ./nginx
    container_name: nginx
    restart: always
    ports:
        - "80:80"
tfserving:
    image: tfserving
    build: ./tfserving
    container_name: tfserving
    restart: always
    expose:
        - 8501
HTTPS runs on a different network port to insecure HTTP.
You need to expose both port 80 (which you already have) and port 443, in order for all of this to work.
You will need to make this change for the nginx service in your docker-compose file:
That should be:
    ports:
        - "80:80"
        - "443:443"
Thank you so much! I knew I had to be overlooking something simple! :orange_heart: :yellow_heart: :green_heart: :blue_heart: :purple_heart: :brown_heart: :black_heart: :white_heart: :heart:
