'utf8' codec error
Hello,
I try to run lestencrypt-auto , and i have these errror :
File “/root/.local/share/letsencrypt/lib/python2.7/encodings/utf_8.py”, line 1
6, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: ‘utf8’ codec can’t decode byte 0xc2 in position 35: invalid
continuation byte
A few days ago, it’s running good.
The server is on ubuntu 14.04
If you can help me.
Regards
PS : Sorry for my english
@pch312, are you using an e-mail address or domain name that contains a non-ASCII character, such as an accented character (åáäàą, etc.) or non-Latin character (like Ж, ξ, ל, or ツ)?
Could you post a more complete error message traceback? There should probably be other information in the output about where the error happened.
Thanks.
Thanks a lot.
I have a file in sites-enabled folder with a special character.
It’s ok now after remove this file
Regards
