Using the ssl for cname
My domain is:ribony.com
I am using Cloudflare for DNS server not as a cdn, and i am using Directadmin. I created SSL with Let’s encrypt and it is working well. You can check it: https://ribony.com. But also i have a CNAME record on Cloudflare, and it is “application.ribony.com” it points to ribony.com. But when i try to access https://application.ribony.com i am getting verification error. How can i fix this problem?
Did you get a certificate for application.ribony.com in DirectAdmin?
No because i can not see application.ribony.com in the list: http://prntscr.com/j9nitb
How is that specific hostname managed in the first place? Does DirectAdmin mention it anywhere at all?
How does http://application.ribony.com work? Or does it?
If it doesn’t, start there and then add TLS after.
