newdealstringband.com (but there are others on the same server, see below)
sudo sympl-ssl --verbose newdealstringband.com
* Examining certificates for newdealstringband.com
SSL set 0: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 1: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 2: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 3: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 4: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 5: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 6: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 7: Not valid for newdealstringband.com -- certificate has expired (10)
SSL set 8: Not valid for newdealstringband.com -- certificate has expired (10)
Current SSL set 13: signed by /C=US/O=Let's Encrypt/CN=R3, expires 2022-01-02 00:50:57 UTC
The current certificate expires in 26 days.
Fetching a new certificate from LetsEncrypt.
Requesting verification for newdealstringband.com from https://acme-v02.api.letsencrypt.org/directory
Successfully verified newdealstringband.com
Requesting verification for www.newdealstringband.com from https://acme-v02.api.letsencrypt.org/directory
Successfully verified www.newdealstringband.com
!! Failed: Order's status ("pending") is not acceptable for finalization
Apache/2.4.38
Debian 10.11
Bytemark
Yes
No
or certbot-auto --version
if you're using Certbot):
I'm not quite sure how to answer this. The documentation here SSL Configuration Reference - Sympl Wiki says, in one place, Sympl uses the ACMEv02 endpoint with Let's Encrypt — but elsewhere on the same page it says that it's possible to specify the endpoint, and says Defaults to https://acme-v01.api.letsencrypt.org/directory.
Importantly, I do not see this error on every domain on the server. Other domain names that do show this error are:
7.hogsedge.net
blazingstrings.co.uk
hogsedge.net
hogsedge.org
longhillramblers.com
pepperpaley.com
I'll be very grateful for any advice! Thank you.
Ben
