I am going to be honest, I thought I was going to be done securing my site with TLS 3 hours ago but boy was I wrong. There is usually not an error I can’t fix after a few minutes but this just ridiculous. When generating a certificate with the staging server everything works. As soon as I remove --staging from the command I get the error below. I am running my site though Cloudflare but I have disabled the routing option so it only acts as a DNS. Any help would be appreciated. It is fairly late so I do not expect a reply tonight and I will update with any solutions I find in the meantime.
My domain is: arkservers.xyz
I ran this command: sudo certbot certonly --webroot --webroot-path=/var/www/html/arkservers -d arkservers.xyz -d www.arkservers.xyz
http-01 challenge for arkservers.xyz
http-01 challenge for www.arkservers.xyz
Using the webroot path /var/www/html/arkservers for all unmatched domains.
Waiting for verification…
Failed authorization procedure. arkservers.xyz (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://arkservers.xyz/.well-known/acme-challenge/qCgxqMONjgZr6IzLIW73_A0dIAL596Rf_lEDzvvbs8Y: Timeout, www.arkservers.xyz (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://arkservers.xyz/.well-known/acme-challenge/ZotxwlhdkpOMVx0s2_5vZOg8HvfyWzviwCYUv5tIQmc: Timeout
Domain: arkservers.xyz
Type: connection
Detail: Fetching
TimeoutDomain: www.arkservers.xyz
Type: connection
Detail: Fetching
Timeout
My web server is (include version): nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: OVH
