Using LE to handle CSRs from OpenFire
#1
My domain is: fenrir.stelth2000inc.com
I ran this command: ./letsencrypt-auto --email demonicpagan@gmail.com --text --authenticator manual --work-dir /tmp/work/ --config-dir /tmp/config/ --logs-dir /tmp/logs/ auth --cert-path /tmp/certs --chain-path /tmp/chains --csr /root/letsencrypt-nosudo/openfire.csr
An unexpected error occurred:
The request message was malformed :: Invalid key in certificate request :: Unknown key type *dsa.PublicKey
My operating system is (include version): Debian Linux 9.0
My web server is (include version): Apache 2.4.23
#2
I’m pretty sure Let’s Encrypt does not support DSA keys. You’ll have to stick to RSA or ECDSA.
Unfortunately, I don’t know anything about OpenFire, but if you could share how you created that key (or point to the relevant documentation), I might be able to help.
#3
This is what I have for documentation for creating TLS/SSL certificates. I have added my RSA LE cert, but am left with the message of
One or more certificates are missing. Click here to generate self-signed certificates or here to import a signed certificate and its private key.
I am presented the message because I do not have a DSA cert in my certificate store.
#4
Which files did you attempt to import? I assume you were using the “Import Signed Certificate” interface mentioned by that guide. Is the error you mentioned something you got as a result of that import, or just a warning message shown somewhere? In case OpenFire requires both a RSA and DSA key to function properly, Let’s Encrypt won’t be able to help you with the DSA key.
#5
I don’t believe it requires both to function. I can live with message it gives about missing certificates. I can still connect to my XMPP server with the RSA one that I have from LE.
#6
