My domain is: menorpreco.biz
My web server is (include version): tomcat 9.0.29 and JVM 11 and apache 2.4.x (worker) with sni and http2 enabled
The operating system my web server runs on is (include version): ubuntu 18.04.1 bionic
My hosting provider, if applicable, is: N/A (firewall open on ports needed)
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ISPConfig3.1 latest patch
or certbot-auto --version
if you’re using Certbot): certbot 0.27.0
I alm trying to get the ISPConfig3 working SSL certificate (which is issued by Let’s Encrypt via certbot) to work for the https secured version of the apache openmeetings project at the following URL
https://menorpreco.biz:5443/openmeetings
It is accessable, however the openmettings project cannot be used because all the major browsers say the site is insecure.
So, to sum up:
https://meorpreco.biz is properly secured by LE cert issued via certbot controlled by ISPConfig3.1 - this when apache 2.4 is running and serving pages.
however
https://menorpreco.biz:5443/openmeetings is NOT secured - regardless of whether or not apache2 is started - tomcat is serving this page.
Can I use the existing LE certificate for menorpreco.biz (served by apache 2.4.x) for port 5443/openmeetings served by tomcat 9?
I tried creting a symbolic link from the /var/www/clients/client0/web2/ssl/ directory which contains the 3 files generated by LE through certbot and ISPConfig3:
menorpreco.biz-le.crt
menorpreco.biz-le.key
and menorpreco.biz-le.bundle
to /opt/open503/conf/keystore
but that didn’t work - I am new at java applications, but must get this openmeetings software working for a community school that is in lockdown because of the coronavirus so classes can continue from home.
So, Can I use the existing LE certificate to secure the same domain served by tomcat 9 on port 5443, and if so, how?
Thank you
