Using Expand to add www subdomain, certbot
My domain is: revkit.com
I ran this command: certbot --expand -d revkit.com -d builds.revkit.com -d rev.revkit.com -d staging.revkit.com -d www.revkit.com
We were unable to find a vhost with a ServerName or Address of www.revkit.com.
Which virtual host would you like to choose?
(note: conf files with multiple vhosts are not yet supported)
1: staging.revkit.com-le-ssl.conf | Multiple Names | HTTPS | Enabled
2: rev.revkit.com.conf | rev.revkit.com | | Enabled
3: staging.revkit.com.conf | Multiple Names | | Enabled
4: rev.revkit.com-le-ssl.conf | rev.revkit.com | HTTPS | Enabled
5: builds.revkit.com-le-ssl.conf | builds.revkit.com | HTTPS | Enabled
6: builds.revkit.com.conf | builds.revkit.com | | Enabled
7: 000-default-le-ssl.conf | revkit.com | HTTPS | Enabled
8: 000-default.conf | | | Enabled
Select the appropriate number [1-8] then [enter] (press ‘c’ to cancel): 8
The selected vhost would conflict with other HTTPS VirtualHosts within Apache. Please select another vhost or add ServerNames to your configuration.
My web server is (include version): Ubunto 16.04 with Apache2
My hosting provider, if applicable, is: DigitalOcean
I can login to a root shell on my machine (yes or no, or I don’t know): YES!
Hi @mikedkap,
Do you have an existing Apache virtual host that directly refers to www.revkit.com?
I don’t (I don’t think so).
I have an A record for www that points to our IP.
Could you maybe add a ServerAlias telling Apache that the revkit.com virtual host can also answer requests for www.revkit.com? After that, I think Certbot will do what you expect.
Hmmm, could you say a little more about that? Where would I start?
Thanks!
grep -r "ServerName revkit.com" /etc/apache2
Then edit that stanza to add
ServerAlias www.revkit.com
within the same stanza. This is also often necessary in order to make Apache respond the way that you expect to requests that use the www form.
I received this message, not sure how to edit it. Much appreciated!
root@testing:~# grep -r "ServerName revkit.com" /etc/apache2
/etc/apache2/sites-available/000-default-le-ssl.conf:ServerName revkit.com
Ah, do I add it into here somewhere?
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
SSLCertificateFile /etc/letsencrypt/live/revkit.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/revkit.com/privkey.pem
Yes, you can add it right after the ServerName line.
