I'm trying to use certbot for the first time to create signed certificates for pages on my local home server. My server is my DNS server, pointing to OpenDNS, and I've edited dnsmasq.conf for the TXT file. I suspect I'm entering it incorrectly:
#Change the following lines to enable dnsmasq to serve TXT records.
#These are used for things like SPF and zeroconf. (Note that the
#domain-name expansion done for SRV records _does_not
#occur for TXT records.)#Example SPF.
#txt-record=example.com,"v=spf1 a -all"#Example zeroconf
#txt-record=_http._tcp.example.com,name=value,paper=A4
> txt-record=_acme-challenge,"zxrQz_bRJlfO2psXSWraPHXT70Rm1K-clw72zEwYhb8"
My domain is: *starfleet.org (local domain)
I ran this command: certbot --text --agree-tos --email t******@*****m -d hda.starfleet.org --manual --preferred-challenges dns --expand --renew-by-default --manual-public-ip-logging-ok certonly
dns-01 challenge for hda.starfleet.org
Please deploy a DNS TXT record under the name
_acme-challenge.hda.starfleet.org with the following value:
Before continuing, verify the record is deployed.
Press Enter to Continue
Failed authorization procedure. hda.starfleet.org (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.hda.starfleet.org
Domain: hda.starfleet.org
Type: None
Detail: DNS problem: NXDOMAIN looking up TXT for
My web server is (include version): Fedora 27
The operating system my web server runs on is (include version): Fedora 27
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes, Amahi 11
