Yes its finally working! Thank you guys so much! I have been on this for days trying to figure it out ... i thought it had something to do with the granted permissions! Thank you thank you thank you!!
I do have another question though ... so i am getting errors in the console a 500 interal server error and i was checking it out and came across this ..... psychphransiscobounce@psychphransisco:~/stocks_with_joe_backend$ sudo nginx -t
psychphransiscobounce@psychphransisco:~/stocks_with_joe_backend$ sudo systemctl restart nginx
psychphransiscobounce@psychphransisco:~/stocks_with_joe_backend$ sudo tail -f /var/log/nginx/error.log
2024/06/27 15:47:01 [warn] 56010#56010: conflicting server name "psychphransisco.com" on 0.0.0.0:80, ignored
2024/06/27 15:47:01 [warn] 56010#56010: conflicting server name "www.psychphransisco.com" on 0.0.0.0:80, ignored
2024/06/27 15:47:01 [warn] 56010#56010: conflicting server name "api.psychphransisco.com" on 0.0.0.0:80, ignored
2024/06/27 17:01:31 [emerg] 56179#56179: "ssl_dhparam" directive is duplicate in /etc/nginx/sites-enabled/default:19
2024/06/27 17:01:31 [emerg] 56180#56180: "ssl_dhparam" directive is duplicate in /etc/nginx/sites-enabled/default:19
2024/06/27 17:01:31 [notice] 56181#56181: signal process started
2024/06/27 19:17:22 [notice] 56617#56617: signal process started
2024/06/27 19:17:23 [notice] 56620#56620: signal process started
^C
What is it you are concerned about there?
The dhparam warnings are from over 2H ago and conflicting name even longer ago. I assume those are fixed from our suggestions. Yes? No?
I just ran that now and say that ssl_dhparam was duplicated again so I didn't know if that was a problem
Later than at 17:01 timestamp?
If so, show output of this again with uppercase T
sudo nginx -T
sudo nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
server_names_hash_bucket_size 128;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
include /etc/nginx/snippets/ssl-dhparams.conf;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/snippets/ssl-dhparams.conf:
ssl_dhparam /etc/nginx/snippets/dhparam.pem;
# configuration file /etc/nginx/sites-enabled/default:
server_name api.psychphransisco.com;
proxy_pass http://localhost:3003;
proxy_http_version 1.1;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
ssl_certificate /etc/letsencrypt/live/psychphransisco.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/psychphransisco.com/privkey.pem; # managed by Certbot
# include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
server_name psychphransisco.com www.psychphransisco.com;
root /home/psychphransiscobounce/stocks_with_joe_frontend;
try_files $uri $uri/ /index.html =404;
#include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
if ($host = www.psychphransisco.com) {
} # managed by Certbot
if ($host = psychphransisco.com) {
listen 80;
It looks all good! Thank you so much for all your help!!
