Urn:ietf:params:acme:error:connection
My domain is: [[redacted]] It’s a client of mine, i can provide the full url in private, or access this private bin please:
https://cryptobin.co/85d6o9f0
pass: helpme
I ran this command: wacs.exe
[WARN] First chance error calling into ACME server, retrying with new nonce…
[INFO] Authorize identifier: mydomain.com
[INFO] Authorizing mydomain.com using http-01 validation (FileSystem)
[INFO] Answer should now be browsable at http:/mydomain.com/.well-known/acme-challenge/aecI0By2tuMjxl0K0BoBAkjVW_eICXyC0jKnh9mIFgA
[INFO] Preliminary validation looks good, but ACME will be more thorough…
[EROR] {
“type”: “urn:ietf:params:acme:error:connection”,
“detail”: “Fetching http://mydomain.com/.well-known/acme-challenge/aecI0By2tuMjxl0K0BoBAkjVW_eICXyC0jKnh9mIFgA: Error getting validation data”,
“status”: 400
[EROR] Authorization result: invalid
My web server is (include version): IIS 8.5
The operating system my web server runs on is (include version): Windows Server 2008 R2
[INFO] A simple Windows ACMEv2 client (WACS)
[INFO] Software version 2.0.3.206 (RELEASE)
[INFO] IIS version 8.5
[INFO] Please report issues at https://github.com/PKISharp/win-acme
Hello sorry for not provide real URL, but its not mine. I’m trying to renew the certs of 3 subdomains of the same domain. All clients that i’ve tried returned the same error.
I’ve tried as in memory (self-hosting) and local file. In local file I can see the files there, i can access the files from other network (3g phone for eg.) But acme server can’t access it… I’m loosing my mind… :frowning:
Please help.
Hi @sxfx
there are two different ipv4 addresses.
But one doesn’t answer if there is a http request.
Perhaps remove the ip address with the timeout.
The other ip address looks good.
Hello @JuergenAuer, thanks for your reply!
Yes, you are right, one of my ips was failing, because my collegue put the firewall interface of it down.
I just wondering why ACME is always resolving for the failing IP, as it has round robin configured…
Cache issues?
