The stream{block} can NOT be inside the HTTP{block}
Cut it out and paste it above HTTP{block} (which should be in the httpd.conf file)
I don’t think i even have a http block, If i move that block to the top of the file i get the same error only pointing to line 1. here is a copy of my default file.
map $http_upgrade $connection_upgrade {
default upgrade;
’’ close;
#Countdown
listen 80;
server_name countdown.example.com;
#Countdown
listen 443 ssl;
root /config/www/countdown;
index index.html index.htm index.php;
ssl on;
ssl_certificate /config/keys/letsencrypt/fullchain.pem;
ssl_certificate_key /config/keys/letsencrypt/privkey.pem;
ssl_dhparam /config/nginx/dhparams.pem;
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
ssl_prefer_server_ciphers on;
try_files $uri $uri/ =404;
#Blog
listen 80;
server_name blog.example.com;
#Blog
listen 443 ssl;
ssl on;
#HomeAssistant
listen 80;
server_name ha.example.com;
#HomeAssistant
listen 443 ssl;
ssl on;
client_max_body_size 0;
proxy_buffering off;
proxy_pass http://192.168.12.202:8123/;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
#Emby
listen 80;
server_name media.example.com;
#Emby
listen 443 ssl;
ssl on;
proxy_pass http://192.168.10.101:8096/;
#AppDaemon
listen 80;
server_name ad.example.com;
#AppDaemon
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.203:5050/;
#Stats
listen 80;
server_name stats.example.com;
#Stats
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.204:3000/;
#qBit
listen 80;
server_name qbit.example.com;
#qBit
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.217:8080/;
# deluge
listen 80;
server_name deluge.example.com;
#Deluge
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.216:8112/;
#Sonarr
listen 80;
server_name sonarr.example.com;
#Sonarr
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.218:8989/;
#jackett
listen 80;
server_name jackett.example.com;
#jackett
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.221:9117/;
#radarr
listen 80;
server_name radarr.example.com;
#radarr
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.219:7878/;
#NextCloud
listen 80;
server_name nextcloud.example.com;
#NextCloud
listen 443 ssl;
ssl on;
proxy_pass https://192.168.12.220:443/;
#MineCraft
listen 80;
server_name minecraft.example.com;
#MineCraft
listen 443 ssl;
ssl on;
proxy_pass https://192.168.12.230:8443/;
#Unifi
listen 80;
server_name unifi.example.com;
#Unifi
listen 443 ssl;
ssl on;
proxy_pass https://192.168.12.200:8443/;
#maximux
listen 80;
server_name mux.example.com;
#maximux
listen 443 ssl;
ssl on;
proxy_pass https://192.168.12.208:443/;
#headphones
listen 80;
server_name headphones.example.com;
#headphones
listen 443 ssl;
ssl on;
proxy_pass http://192.168.12.213:8181/;
stream {
listen 80;
server_name mqtt.example.com;
proxy_pass 192.168.12.201:1883/;
proxy_connect_timeout 1s;
Everyone has an http block.
It is in another file.
You are probably in an included file.
Do you have the file?:
/etc/nginx/nginx.conf
It should look like this:
#user nobody; worker_processes 1; #error_log logs/error.log; #error_log logs/error.log notice; #error_log logs/error.log info; #pid logs/nginx.pid; events { worker_connections 1024; } http { include mime.types; default_type application/octet-stream; #log_format main '$remote_addr - $remote_user [$time_local] "$request" ' # '$status $body_bytes_sent "$http_referer" ' # '"$http_user_agent" "$http_x_forwarded_for"'; #access_log logs/access.log main; sendfile on; #tcp_nopush on; #keepalive_timeout 0; keepalive_timeout 65; #gzip on; server { listen 80; server_name localhost; ...
i used the same block and put it into the nginx.conf file just above the http block, and i’m not getting any errors on lets encrypt, but the log file is saying the connection error.
194.80.20.10 - - [11/Dec/2018:19:03:47 +0000] "\x10V\x00\x04MQTT\x04\xEE\x00" 400 173 "-" "-"
Scrap that. restart letsencrypt and getting “stream is not allowed here”
## Version 2018/01/29 - Changelog: https://github.com/linuxserver/docker-letsencrypt/commits/master/root/defaults/nginx.conf
user abc;
worker_processes 4;
pid /run/nginx.pid;
include /etc/nginx/modules/*.conf;
events {
worker_connections 768;
# multi_accept on;
stream {
listen 80;
http {
hmm....
Please show everything you added.
lol, i think i edited my post whilst you were replying. i’ve just realised the i put that inside another block. just editing it now.
EDIT:
user abc;
worker_processes 4;
pid /run/nginx.pid;
events {
# multi_accept on;
stream {
listen 80;
proxy_connect_timeout 2s;
nginx: [emerg] "server_name" directive is not allowed here in /config/nginx/nginx.conf:17
Streams don’t have “server names” - rem that line out.
And try it on any other unused port (not 80 and not 443).
For now, also rem out the proxy connect timeout line.
this is where the problem lies, i need to have it come in on a port that is “open” from work. (I work in a school and the open ports are controlled by the LA so opening them is a nightmare)
I’m trying to use reverse proxy so that all connections come over the same port numbers.
I’ll make the changes and try it on an internal device though.
If i edit those two lines out, i’m now “getting invalid host in upstream.”
First get it to work.
Then change the port number.
pmsl. fair play. invalid host in upstream apparently.
Try removing the slash after :1883
I changed it to port 21, and removed the “/” on the host, letsencrypt is now running with no errors.
I don’t see any connection attempts in the logfile file, but still getting an error on the mqtt client.
Try switching it to some higher port like 8000
and also back to 80.
Which ones break?
How?
Do you get an error message?
Do you have another MQTT client?
currently testing on port 8080.
same results. no connection i’m testing with two clients to be sure, one inside the firewall (on the same vlan) and one outside the network, with the port in question forwarded.
if i change it to port 80 i get an emergency error telling me it cannot bind.
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address in use)
show who is using port 80 (probably nginx itself):
netstat -pant | grep 80
This is a docker running on its on ip, so i would assume it's nginx too, but the results are:
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1019/nginx
Yes, nginx can’t do http on 80 and stream on 80
Same IP & Same port @ Same Time = Problem!
Do you have more than one external IP?
Or IPv4 and IPv6?
I don’t have more than one ip address no, my ISP also doesnt yet provide ipv6 addresses.
So only one external IP.
Have you tried to determine which ports can reach your IP?
(nmap)
Perhaps port 53 ?
