Got this error while issuing certificate through cpanel, my domain is www.pubcrawl.barcelona
There was a problem processing your request
Error issuing certificate
Failed to issue certificate
Updating challenge for autodiscover.pubcrawl.barcelona: acme: error code 400 "urn:ietf:params:acme:error:dns": DNS problem: NXDOMAIN looking up A for autodiscover.pubcrawl.barcelona - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for autodiscover.pubcrawl.barcelona - check that a DNS record exists for this domain (order URL: https://acme-v02.api.letsencrypt.org/acme/order/724490697/285794174757)
Well, in addition to www.pubcrawl.barcelona, that order you linked shows that your system is trying to get several more names on the certificate, including autodiscover.pubcrawl.barcelona. But that name doesn't exist. So, you either need to have that domain name exist and point to your server (if you need that name), or have it not be a part of the certificate request (if you don't need that name). I'm not sure how to do either of those things through cPanel, but if that's your only access to your server then your hosting provider should be able to help you with that.
Hey Peter! Thanks a lot for the superfast answer i appreciate it a lot.
I don't know even why autodiscover.pubcrawl.barcelona apperas, never register that domain and is actually the 1st time i hear about it. Thanks for your information. I will contact my hosting provider asking them for a hand!
