The command is certbot certificates
(you omitted the last s
Although, looking at your other commands it should probably be:
sudo certbot certificates
These commands were also typed wrong. You are using the number 1 and not a lower case L. Should be:
sudo systemctl restart nginx
sudo journalctl -eu nginx
nginx -t
Doesn't provide much output.
nginx -T
Could show the entire config.
