Problem description: I tried to get certificates for two websites. One appears to be ok (www.mediamagnet.nl). The other one has failed (www.bi-magnet.nl).
This is strange because both websites are on the same server and I just newly installed this server with Lubuntu 18.04. There is nothing else on this server as it is intended to purely service my two websites.
Question: What would be the steps to get this problem solved?
www.bi-magnet.nl
www.mediamagnet.nl
user@webserver:~$ ./certbot-auto
1: bi-magnet.nl
2: www.bi-magnet.nl
3: mediamagnet.nl
4: www.mediamagnet.nl
blank to select all options shown (Enter ‘c’ to cancel):
http-01 challenge for bi-magnet.nl
http-01 challenge for mediamagnet.nl
http-01 challenge for www.bi-magnet.nl
http-01 challenge for www.mediamagnet.nl
Enabled Apache rewrite module
Waiting for verification…
Challenge failed for domain www.bi-magnet.nl
Challenge failed for domain bi-magnet.nl
Domain: www.bi-magnet.nl
Detail: Invalid response from
https://www.bi-magnet.nl/.well-known/acme-challenge/dxMWQpzrWizLNtBop5jOecYq5cdWUUmbdZDPxBXZkuI
[2a02:4a8:ac24:117::101:3]: “\r\n404 Not
Found\r\n\r\n404 Not
\r\n
Found
nginx\r\n”Domain: bi-magnet.nl
https://bi-magnet.nl/.well-known/acme-challenge/3nPMuUsq3xaJiwJOmD0fDyBUHpOc_quJt5qYxNZ8rDI
\r\n
Found
nginx\r\n”To fix these errors, please make sure that your domain name was
contain(s) the right IP address. -
Your account credentials have been saved in your Certbot
twan@SYS2:~/Documents$
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-06-27T17:05:04
Lubuntu 18.04.2
Own server
Yes
No
or certbot-auto --version
if you’re using Certbot):
