My web server is:
nginx
ubuntu 16.04
digitalocean
This isn't a correct diagnosis of the problem in this case, because the Let's Encrypt CA specifically ignores certificate validation errors resulting from a 301 redirection from HTTP to HTTPS when verifying HTTP-01 challenges. As a result, the behavior of the challenge URL in an ordinary browser isn't exactly reflective of what the CA will decide.
But if the CMS is redirecting all queries, then there is no other directory that could be specified with -w. An exception in the CMS redirection would need to be added to allow the contents of /.well-known/acme-challenge to be served as static files.
However, since he is using nginx, cms would add redirection on Nginx vHost rather than htaccess (which is Apache ). If using webroot, it will avoid the vHost(if I remembered correctly)
