Unable to use certbot docker container with manual-auth-hook and manual-cleanup-hook
#!/bin/sh is fine by me :wink:
Looks like shellcheck throws out some warnings and infos, but I'm guessing nothing that can't be fixed. Should be workable using #!/bin/sh I'm guessing..
Still needs to have curl installed somehow though.
I see there are many solution to the issue.
We went with the solution proposed by @Osiris because the plugin works perfectly for our use case.
Installing the plugin into the docker container is quite straight forward and even explained in the documentation of the repository
Thank you guys!!!
