My domain is: www.expo.exchange
Using jrcs/letsencrypt-nginx-proxy-companion
Creating/renewal www.expo.exchange certificates... (www.expo.exchange)
2017-02-21 03:03:17,442:INFO:simp_le:1211: Generating new account key
2017-02-21 03:03:18,443:INFO:requests.packages.urllib3.connectionpool:756: Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
2017-02-21 03:03:19,436:INFO:requests.packages.urllib3.connectionpool:756: Starting new HTTPS connection (1): letsencrypt.org
2017-02-21 03:03:20,460:INFO:requests.packages.urllib3.connectionpool:207: Starting new HTTP connection (1): www.expo.exchange
2017-02-21 03:05:27,857:ERROR:acme.challenges:256: Unable to reach http://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI: HTTPConnectionPool(host='www.expo.exchange', port=80): Max retries exceeded with url: /.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd7ecfe7190>: Failed to establish a new connection: [Errno 110] Operation timed out',))
2017-02-21 03:05:27,858:WARNING:simp_le:1303: www.expo.exchange was not successfully self-verified. CA is likely to fail as well!
2017-02-21 03:05:28,073:INFO:simp_le:1313: Generating new certificate private key
2017-02-21 03:05:29,013:INFO:simp_le:391: Saving account_key.json
2017-02-21 03:05:29,014:INFO:simp_le:391: Saving key.pem
2017-02-21 03:05:29,014:INFO:simp_le:391: Saving chain.pem
2017-02-21 03:05:29,015:INFO:simp_le:391: Saving fullchain.pem
2017-02-21 03:05:29,015:INFO:simp_le:391: Saving cert.pem
Reloading nginx proxy...
My web server is (include version): Nginx-proxy
My hosting provider, if applicable, is: Docker on DigitalOcean, DNS via Route53
More Details:
When I hit the challenge URL directly, it force downloads a file. Not sure why the connection is timing out for LetsEncrypt.
schoen
February 21, 2017, 3:22am
2
Hi @danmandle , one possibility would be a firewall rule on the server that stops it from connecting directly to itself (thus making simp_le
wrongly think that the challenge isn’t set up correctly). Could you try accessing the challenge URL with curl
on your server, instead of from your browser on your desktop computer? Do you see the same contents that way as you do in the file that gets downloaded in the browser?
Thanks for the quick response! Good thinking on the curl
command. You’re right:
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.11.9</center>
</body>
</html>
So that’s interesting. I’ll have to take a closer look at why that’s happening.
schoen
February 21, 2017, 3:28am
4
You can add a -v
to find out where it thinks it moved to… that might help for investigating this further.
$ curl -vI http://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI
* Trying 138.68.228.41...
* Connected to www.expo.exchange (138.68.228.41) port 80 (#0)
> HEAD /.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI HTTP/1.1
> Host: www.expo.exchange
> User-Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0)
> Accept: */*
> Referer:
< HTTP/1.1 301 Moved Permanently
< Server: nginx/1.11.9
< Date: Tue, 21 Feb 2017 03:42:39 GMT
< Content-Type: text/html
< Content-Length: 185
Content-Length: 185
< Connection: keep-alive
< Location: https://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI
* Connection #0 to host www.expo.exchange left intact
dm-macbook:~ danmandle$ curl -vI
dm-macbook:~ danmandle$ curl -vLI http://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI
> Accept: */*
> Referer:
< Date: Tue, 21 Feb 2017 03:42:54 GMT
Content-Length: 185
* Issue another request to this URL: 'https://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI'
* Found bundle for host www.expo.exchange: 0x7fcfc150fee0
* Connected to www.expo.exchange (138.68.228.41) port 443 (#1)
* TLS 1.2 connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
* Server certificate: www.expo.exchange
* Server certificate: Let's Encrypt Authority X3
* Server certificate: DST Root CA X3
> Accept: */*
> Referer: http://www.expo.exchange/.well-known/acme-challenge/6qJfCUjX0RbwYjclZ5rQoa09R4WG2wFEDtIuSbBOQLI
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Content-Type: application/octet-stream
< Content-Length: 87
Content-Length: 87
< Last-Modified: Tue, 21 Feb 2017 03:03:20 GMT
< ETag: "58abadf8-57"
ETag: "58abadf8-57"
< Strict-Transport-Security: max-age=31536000
< Accept-Ranges: bytes
* Connection #1 to host www.expo.exchange left intact
schoen
February 21, 2017, 4:24am
6
Can you get the challenge response with curl -L
, which should follow the redirect?
system
Closed
March 23, 2017, 4:24am
7
