I am trying to set up SSL access to my server (who’d guessed it). My setup is the following:
domain christianzollner.com is permantently redirecting with masking to christianzollner.ddns.net (no-ip service) which is then pointing to my raspberry pi server.
I was able to set up the SSL certificate for christianzollner.ddns.net but I am struggling to set it up for the christianzollner.com domain and I ran out of clues. The command shown below is the latest one I tried, so I guess it’s a starting point. To me it seems somehow that the certbot isn’t following the forwarding from the top-level domain to the no-ip service - but really, I am just guessing.
I ran this command: sudo certbot certonly --apache -d christianzollner.com --dry-run
http-01 challenge for christianzollner.com
Enabled Apache rewrite module
Waiting for verification…
Failed authorization procedure. christianzollner.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://christianzollner.com/.well-known/acme-challenge/H_TK2a5UYnX01KWVO3Uj3cWw-bFaQNFXZP8cJq7Clzg: Timeout during connect (likely firewall problem)
Server version: Apache/2.4.38 (Raspbian)
Server built: 2019-10-15T19:53:42
The operating system my web server runs on is (include version): Raspbian Buster
My hosting provider, if applicable, is: self-hosted on my Raspi
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): cerbot 0.31.0
Thanks again, Herr Auer! I changed the CNAME record from my registrar to point to christianzollner.ddns.net and (after a little while) it worked! Great!
working with SSL. This is because my registrar won’t accept “@” in my CNAME record (is this normal?) and I can’t provide a (corret) static IP adress for an A record. I also tried forwarding christianzollner.com to https://christianzollner.ddns.net but then again, my registar automatically creates an A record with the IP adress of my top-level domain (where I can’t install certificates).
