Unable to get secret after running certificate yml
I have a domain which is in public domain in cloud env. and that has already having lets encrypt certs.
But, when I am creating another subdomain certificate, it is not generating TLS certificate in secret , only Key is there.
When I checked the order status it says in Pending state.
The domain has LoadBalancer IP, however the IP of the loadBalancer is not attached with service ingress, only HOSTNAME is coming up without LB IP ADDRESS.
How to solve this issue.Kindly Guide.Thanks.
It is possible that the ACME client precheck for http access to the subdomain name is failing because there is no ingress controller connected to respond for the subdomain name.
To me, you're talking a lot of gibberish, probably because I lack an understanding of the setup you're talking about. Let's start with the basics, in the form of the questionnaire you should have been presented with (or which you have deleted, either one of those) when opening this thread in the #help section. Please answer all the questions to the best of your knowledge:
Sorry Osiris, I am not getting your point.
The workstation is not in 192.168.x.x , it is in 10.x.x.x series.
What will be the reason that A.example.com is able to retrieve the certificate.
However, B.example.com is unable to get lets encrypt certicate.
The subdomain B.example.com has connected with Ingress-controller.
Issuer Ref:
Secret Name: B.example.com.centralus.cloudapp.azure.com
Status:
Conditions:
Last Transition Time: 2022-09-12T14:18:37Z
Message: Issuing certificate as Secret does not exist
Observed Generation: 1
Reason: DoesNotExist
Status: True
Type: Issuing
Last Transition Time: 2022-09-12T14:18:38Z
Message: Issuing certificate as Secret contains an invalid key-pair: tls: failed to find any PEM data in certificate input
Observed Generation: 2
Reason: InvalidKeyPair
Status: False
Type: Ready
Next Private Key Secret Name: mvp-preview2-idp-ra.centralus.cloudapp.azure.com-6mq88
Events:
I am not using certbot, I have below yml file to generate certificate which gave above error messages, when I described the certificates error
apiVersion: cert-manager.io/v1
kind: Certificate
metadata:
namespace: mvp-preview2
spec:
secretName: B.example.centralus.cloudapp.azure.com
issuerRef:
dnsNames:
Below is the ingress output, which says that it has domain and ingress-class attached, but LB IP is not able to attach.Not sure the reason,
k get ingress -n mvp-preview2
NAME CLASS HOSTS ADDRESS PORTS AGE
B-service-ingress ingress-internal B.example.centralus.cloudapp.azure.com 80, 443 22h
cm-acme-http-solver-qgpgv B.example.centralus.cloudapp.azure.com 80 5h10m
k get svc -n ingress-nginx-mvp-preview-2
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
ingress-nginx-controller LoadBalancer 10.0.130.70 52.189.31.62 80:30081/TCP,443:31400/TCP 20h
ingress-nginx-controller-admission ClusterIP 10.0.217.214 443/TCP 20h
The questionnaire is usually the starting point of a thread to have the most basic information present to start with, instead of diving deep into very specific details. Having many details without the basics and without any cohesion often makes it difficult to understand the situation for outsiders.
Hello @gsingh86
Thank you for assisting us in helping YOU!
My domain is: mvp-preview2-idp-ra.centralus.cloudapp.azure.com
I ran this command: kubectl get orders -A
It produced this output: mvp-preview2 mvp-preview2-idp-ra.centralus.cloudapp.azure.com-wv6-1904620340 pending 6h42m
My web server is (include version): Linux 5.10.16.3-microsoft-standard-WSL2 ( Workstation)
The TSL secret is not generating for mvp-preview2-idp-ra.centralus.cloudapp.azure.com, causes unable to generate certificate
We have mvp-preview-idp-ra.centralus.cloudapp.azure.com, which already have TLS certificate and in the same subnet.
I am not getting why the mvp-preview2-idp-ra.centralus.cloudapp.azure.com, not able to retrieve certificate.
kubectl describe certificate output:
Issuer Ref:
Status:
Conditions:
Status: True
Type: Issuing
Status: False
Type: Ready
Events:
I don't know your ACME client or config very well. But, it sounds like they should be similar yet they look different to me.
The DNS IP are to different IP. Is that intended?
nslookup mvp-preview-idp-ra.centralus.cloudapp.azure.com
Address: 13.86.32.78
nslookup mvp-preview2-idp-ra.centralus.cloudapp.azure.com
Address: 20.236.224.240
AND, I get an HTTP response from preview but not from preview2 (which times out)
curl -I -m10  mvp-preview-idp-ra.centralus.cloudapp.azure.com
HTTP/1.1 308 Permanent Redirect
Date: Sat, 17 Sep 2022 17:46:20 GMT
Location: https://mvp-preview-idp-ra.centralus.cloudapp.azure.com
curl -I -m10  mvp-preview2-idp-ra.centralus.cloudapp.azure.com
curl: (28) Connection timed out after 10000 milliseconds
The preview2 domain should respond on http if you are using the HTTP Challenge.
You may need to ask on a kubernetes forum for config help to resolve why this happens.
Hello Team,
These both subdomains belongs to same aks cluster and isolated with different namespace .
DNS is created with Public IP Address which has IP address provided by DHCP.
And does that DHCP up DNS with updated A and/or AAAA Records when it issues a new IP Address?
And does that propagate all the way out to the Internet visible DNS servers?
And what is the TTL for those DNS Records?
It is all maintained by AKS , so difficult to describe about DHCP setup
Forgive my ignorance, but who or what is AKS? :confused:
Azure Kubernetes service
Its a kubernetes cloud service provided by Azure.
I cannot do much on DNS side, can you suggest any alternatives?
Can you choose another Challenge Types - Let's Encrypt or uses a a Wildcard certificate?
Can you share the steps for generating Wildcard certificate
