Right, So I have spun up another VM, different name, IP ect, got apache working and I went to the CNAME I set which is music.sopel.dev, I go to the padlock, inspect the certificate (I have NOT run certbot yet) and it says common name is nextcloud.sopel.dev, why?
I nuked the other server, I am getting error now though. Please see below:
s0ap@music:~$ sudo certbot
1: music.sopel.dev
Requesting a certificate for music.sopel.dev
http-01 challenge for music.sopel.dev
Enabled Apache rewrite module
Challenge failed for domain music.sopel.dev
Domain: music.sopel.dev
Type: connection
Detail: 185.222.21.139: Fetching
http://music.sopel.dev/.well-known/acme-challenge/Kc3qntfbdPzMwN4gb757n22y48iPrnvdjZMMQIy0qUY:
Error getting validation data
And your output is:
s0ap@music:~$ sudo ss -tlpn
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:* users:(("systemd-resolve",pid=966,fd=14))
LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=1611,fd=3))
LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=1611,fd=4))
LISTEN 0 511 *:80 *:* users:(("apache2",pid=4416,fd=4),("apache2",pid=4415,fd=4),("apache2",pid=3039,fd=4))
Like I said in my initial post, I made a mistake and I added nextcloud.sopel.dev and sopel.dev as A records, pointing to the same IP address. When I can certbot for my nextcloud server it worked just fine, everything after that stopped working (apart from nextcloud) once I removed nextcloud.sopel.dev as an A record and made it a CNAME record. Are certbot servers still using the old A record that I deleted?
I am using ESXi, each server is a separate VM. Each VM has only one service running. That's what I am suspecting, every instance I run from any server somehow references nextcloud.sopel.dev even though it's already gone. I think I nuked my own domain
Hi, just to let you know, I followed your advice but instead of caddy I set up a dedicated nginx server as a reverse proxy and for SSL. Everything is working now. Thank you a lot.
