Hello,
I’ve, until now, generated tens of thousands of LE certificates (thanks by the way). Today, i’m meeting an issue on odette.pro. The DNS are well configured but i always get an invalid authorization after verifying the challenge. My HTTP server doesn’t received the .well-known request. Any ideas?
Regards,
Xavier
Thanks for providing the domain name - I had a quick look but I don’t see an immediately obvious problem. Could you fill out the rest of the template questions please?
Thanks for your quick reply.
I’m the hosting provider.
The server is Debian Jessie, but we have our own proxy.
The Apache version is 2.2.32.
When i run client.answer_challenge(challenge, response), i get:
ChallengeResource(body=ChallengeBody(chall=HTTP01(token=’…’), status=Status(pending), validated=None, uri=u’https://acme-v01.api.letsencrypt.org/acme/challenge/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8/2409687330’, error=None), authzr_uri=‘https://acme-v01.api.letsencrypt.org/acme/authz/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8’)
Then, get the authorizations :
authorization = messages.AuthorizationResource(
uri=auth_uri,
body=messages.Authorization.from_json(response.json()),
new_cert_uri=self.client.directory.new_cert
AuthorizationResource(body=Authorization(status=Status(invalid), challenges=(ChallengeBody(chall=TLSSNI01(token=…’), status=Status(pending), validated=None, uri=u’https://acme-v01.api.letsencrypt.org/acme/challenge/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8/2409687329’, error=None), ChallengeBody(chall=HTTP01(token=’…’), status=Status(invalid), validated=None, uri=u’https://acme-v01.api.letsencrypt.org/acme/challenge/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8/2409687330’, error=Error(typ=u’urn:acme:error:unauthorized’, detail=u’The key authorization file from the server did not match this challenge [ss2rbXANZlOoUp0w0aqh_8CkvAJ50TBgrMj1-Rzn5GI.3KfGAThFF8OhEOseYq65ig-BghPi6dBjjYyzBfwiVF4] != [ss2rbXANZlOoUp0w0aqh_8CkvAJ50TBgrMj1-Rzn5GI.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8]’, title=None)), ChallengeBody(chall=DNS01(token=’…’), status=Status(pending), validated=None, uri=u’https://acme-v01.api.letsencrypt.org/acme/challenge/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8/2409687331’, error=None)), identifier=Identifier(typ=IdentifierType(dns), value=u’odette.pro’), expires=datetime.datetime(2017, 11, 14, 11, 31, 49, tzinfo=), combinations=((0,), (2,), (1,))), new_cert_uri=u’https://acme-v01.api.letsencrypt.org/acme/new-cert’, uri=u’https://acme-v01.api.letsencrypt.org/acme/authz/y06agJV57fk4Nl_Q3wrNXIfBheVwtaSko0O8vb6D0c8’)
Is this an inbound proxy? Maybe you should exclude the location /.well-known/acme-challenge from proxying and pass these requests right to the destination. Otherwise you may want to process certificate issuance directly on the proxy itself.
I just realized that our client had configured well the ipv4 but a wrong ipv6
Thanks for your support!
