My domain is: ejmpa.tech
I ran this command: sudo certbot certonly --standalone
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): ejmpa.tech
Requesting a certificate for ejmpa.tech
My web server is (include version): nginx latest version (1.18.0-0ubuntu1.4).
The operating system my web server runs on is (include version): ubuntu 20.04 LTS
@EJmpa In your setup, the recommended command would usually be something like
sudo certbot --nginx
and not
The sudo certbot certonly --standalone command is intended for a very different environment than yours. I imagine @rg305 is concerned that you may be following some kind of tutorial or documentation that doesn't apply to your situation.
It's possible that in this setup certbot --standalone could be useful, but in that case you should not be running nginx listening on port 80.
I'm not sure if the teacher (?) who proposed this task has a preferred strategy or path to dealing with this or if you can use any option or arrangement. Also if you just need a "demo" solution that would work temporarily but fail to renew the certificate when it expires, or if you need a "sustainable" solution that would in principle continue to work in the future.
