Done:
listen 80;
listen 443 ssl;
server_name obiektywnarozkosz.pl;
# root /var/www/obiektywnarozkosz.pl;
rewrite ^/(.*)$ https://www.obiektywnarozkosz.pl/$1 permanent;
# return 301 http://www.obiektywnarozkosz.pl;
listen 80;
listen 443 ssl;
access_log /var/log/nginx/access.log main;
index index.php;
server_name www.obiektywnarozkosz.pl;
if ($request_uri ~ "/index.(php|html?)") {
rewrite ^ /$1 permanent;
# location / {
# try_files $uri $uri/ /index.php;
location ~* \.(jpg|jpeg|png|gif|ico|css|js|woff)$ {
expires 365d;
location ~ (\.sql.gz|\.sql) { return 403; }
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/var/run/php5-fpm.sock;
# fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi_params;
And got the error:
Failed authorization procedure. www.obiektwynarozkosz.pl (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for www.obiektwynarozkosz.pl
Domain: www.obiektwynarozkosz.pl
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for
