Two Questions: (a) Renewal (b) Invalid Intermediate
That won't actually install the cert(s).
It ONLY gets the cert(s).
So this is expected:
Start your troubleshooting with:
sudo apachectl -S
Thx for the info'. I'm actually attempting this on a different server to the previous stuff I was doing, which I'd kinda used as a trial-run, where I eventually got it all working okay, so I figured it should be fairly straightforward, with the same version of CentOS and the same version of Apache, but guess I'm missing something.
Yeah, I was only trying to get the certs, rather than install them, and I manually added the code-block to the vhost in the same manner as before. Also restarted the server, after I tried a couple of different domains, each time, but same problemo. Curious. I'm just trying to do one domain at a time for now, but seems to make little difference.
I bow to Rudy's (@rg305) excellent suggestion. Post the output of that command with three backticks on the lines above and below the output.
Okay, well, please excuse the slight obfuscation of unrelated domains in the output, but the one I'm attempting this with is shopviews.com, the information of which I've kept as-is. Other than domain names everything is precisely as output.
Actually, I needed to do "httpd -S" on the CentOS server, as apachectl -S didn't produce anything:
$ sudo httpd -S
VirtualHost configuration:
10.0.0.5:*             xyz.com (/etc/httpd/conf/httpd.conf:396)
10.0.0.5:443           xyz.com (/etc/httpd/conf/httpd.conf:428)
51.141.109.36:443      shopviews.com (/etc/httpd/conf/httpd.conf:824)
*:443                  dgbvm.internal.cloudapp.net (/etc/httpd/conf.d/ssl.conf:56)
*:80                   is a NameVirtualHost
         default server xxx.net (/etc/httpd/conf/httpd.conf:464)
         port 80 namevhost xxx.net (/etc/httpd/conf/httpd.conf:464)
                 alias www.xxx.net
                 alias yyy.com
                 alias www.yyy.com
                 alias dpp.com
                 alias www.dpp.com
         port 80 namevhost sbs.co.uk (/etc/httpd/conf/httpd.conf:509)
                 alias www.sbs.co.uk
         port 80 namevhost www.aaa.co.uk (/etc/httpd/conf/httpd.conf:544)
                 alias aaa.co.uk
         port 80 namevhost www.bbb.us (/etc/httpd/conf/httpd.conf:574)
                 alias bbb.us
         port 80 namevhost www.shopviews.com (/etc/httpd/conf/httpd.conf:796)
                 alias shopviews.com
ServerRoot: "/etc/httpd"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex authdigest-opaque: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: _RH_HAS_HTTPPROTOCOLOPTIONS
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: MODSEC_2.5
Define: MODSEC_2.9
User: name="apache" id=48
Group: name="apache" id=48
I've tried using a vhost both as (a) and then as (b) below, but same result with each.
<VirtualHost 51.141.109.36:443>
ServerName shopviews.com
ServerAlias www.shopviews.com
</VirtualHost>
<VirtualHost *:443>
</VirtualHost>
FYI, note that the 10.0.0.5 IP address is mapped to a secondary public IP address, and is separate to all the others. That is, all the other domains listed share a completely different IP (as given). (and, as already noted, the domain with the GoDaddy cert, xyz.com, works fine).
Thank you in advance for any help in the right direction.
How is this working?
Are you really trying to bind httpd to every single port on that IP?
This will only bind if this address is actual on the local system:
Please show:
sudo ifconfig | grep -Ei 'add|inet'
Please show the server block that contains: /etc/httpd/conf/httpd.conf:796
Okay, got it working. Thx.
